Thread: Problem on one side of engine??
Results 11 to 20 of 22
  1. Re: Problem on one side of engine??
    #11
    Nov 2016
    england
    33 Post(s)
    The injectors wear, it is a well known and VAG acknowledged problem dealt with by installing an upgraded set of injectors. The noise is usually a blocked breather system caused by poor oil change intervals, i.e. the ones recommuby Audi......
    Ah ok thank you, do you have an idea of how to find and clear the blockage, have you had this injector problem? Are they easy to do? Do you have a part number for the upgraded set? Are they audi dealers only or can I source them elsewhere? Sorry for the multiple questions but i really appreciate the help, I've never had injectors go on any of the cars I've had before
  2. Re: Problem on one side of engine??
    #12
    Nov 2016
    england
    33 Post(s)
    Would I need all the injectors replacing or just any bad ones only I've looked on eBay just to get a rough idea of a price and they want £250 each for a remanufactured one
  3. Re: Problem on one side of engine??
    #13
    1840 Post(s)
    You should fit the upgraded part (all six) 059 130 855 AX which are £508.87 inc VAT from Audi, that is EACH... Yes the IMA values have to be read off of the injector and entered into the engine ECU. You should be able to find the Bosch exchange version 0 986 435 358 for around £300 each.
  4. Re: Problem on one side of engine??
    #14
    Nov 2016
    england
    33 Post(s)
    Thank you, i went out and had a look this afternoon and I don't know if maybe when i see smoke before it was due to it being damp as it was early morning but today it didn't really kick out much smoke on idle, or mid range of revs, it did kick out a load of white smoke with my foot to the floor (literally) this to only be about 4,000 revs or slightly less, this is the highest it will rev and towards this many revs will also produce smoke from what looks like underneath my coolant bottle maybe at the backend of the manifold or just behind it? I was hoping to do a scan but i ran out of time so I will do one tomorrow and check the measuring blocks too
  5. Re: Problem on one side of engine??
    #15
    Nov 2016
    england
    33 Post(s)
    Hi Crasher so I went and started the car the other day and It didn't seem to get hot on one side, so Intermittent fault? Though the fans didn't seem to come on and i did miss this from my scan
    005716- please check dtc memory of instrument cluster
    P1654 -005- - Intermittent
    Freeze Frame
    Fault Status :00100101
    Fault Priority :0
    Fault Frequency :6
    Reset counter :255
    Mileage :293510 km
    Time Indication :0
    Date: 2005.11.06
    Time :9:20:28
    Freeze Frame
    Rpm: 0/min
    Torque :0.0nm
    Speed :0.0 km/h
    Duty cycle: 1.0%
    Voltage :12.92 v
    Bin.bits: 00101000
    Torque: 109.2
    Readiness: 1 1 0 0 0
    I think this refers to an engine coolant temperature sensor? In my instrument cluster section it shows no fault found but i had just cleared my fault codes before i started the car and did this scan so maybe it hadn't had a chance to register a fault in the instrument cluster section as its an Intermittent fault and i hadn't run the car for very long? I need to do another scan but have had computer problems, p.s i know the date says 2005 but I've also got current faults with my light/rain sensor which I've had for a year and the date showing for them is 2006 for some reason?
  6. Re: Problem on one side of engine??
    #16
    1840 Post(s)
    Do another scan in a few days and see what comes back.
  7. Re: Problem on one side of engine??
    #17
    Nov 2016
    england
    33 Post(s)
    That scan was a few weeks back trying to do another one at the minute but having problems with my computer , just getting frustrated at the minute because i want my car back ha ha ha
  8. Re: Problem on one side of engine??
    #18
    1840 Post(s)
    Computers and cars, I never get frustrated with them, ever........
  9. Re: Problem on one side of engine??
    #19
    Nov 2016
    england
    33 Post(s)
    Ha ha ha yeah exactly why I stopped working on cars years ago (i was in a better situation so could pay someone else to get frustrated,to be honest now i also want to solve it because the frustration lol), newer engines are a current frustration, computers however have always been so
  10. Re: Problem on one side of engine??
    #20
    Nov 2016
    england
    33 Post(s)
    Hi Crasher i did manage to do a scan today this is the faults that showed up
    Address 01: engine
    Freeze Frame
    Fault Priority: 0
    Fault Frequency: 23
    Reset counter :255
    Mileage: 293510 km
    Time Indication: 0
    Date 2005.11.06
    Time :09:20:28
    Freeze Frame :
    Rpm: 0/min
    Torque: 0.0 nm
    Speed: 0.0 km/h
    Duty cycle: 1.0 %
    Voltage: 12.92 v
    Bin.bits: 00101000
    Torque: 109.2 nm
    006217- please check dtc memory of transmission controller
    P1849- 008- -Intermittent
    Freeze Frame :
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 6
    Reset counter: 255
    Mileage: 0 km
    Time Indication :0
    Freeze Frame :
    Rpm: 0/min
    Torque :230.1 nm
    Speed: 0.0 km /h
    (no units) :0.0
    Voltage :5.40 v
    Torque: 581.4 nm
    005481 - cruise control switch (e45)
    P1569- 001 - implausible signal - Intermittent
    Freeze Frame :
    Fault Status: 00100001
    Fault Priority :0
    Fault Frequency :2
    Reset counter :255
    Mileage :0 km
    Time Indication :0
    Freeze Frame
    Rpm :21/min
    Torque: 226.2 nm
    Speed :0.0 km/h
    Duty cycle :1.0%
    Voltage :5.32v
    Bin.bits :00001000
    Torque :292.5 nm
    005715- please check dtc memory of abs controller
    P1653-002- - Intermittent
    Freeze Frame :
    Fault Status :00100010
    Fault Priority :0
    Fault Frequency :4
    Reset counter :255
    Mileage: 296862 km
    Time Indication :0
    Date :2006.06.13
    Time:11:15:53
    Freeze Frame :
    Rpm :0/min
    Torque :0.0 nm
    Speed :0.0 km/h
    Duty cycle: 1.0 %
    Voltage :10.49v
    Bin.bits: 00101000
    Torque :109.2 nm
    I also have a intake manifold flap fault i knew about already and 3 glowplugs dead
    Address 03: abs brakes
    1 fault found :
    01826- sensor for steering angle (g85);supply voltage terminal 30
    000- - - Intermittent
    Freeze Frame :
    Fault Status :00100000
    Fault Priority :3
    Fault Frequency :23
    Reset counter: 107
    Mileage :296862km
    Time Indication: 0
    Date :2006.06.21
    Time: 11 :10:35
    Freeze Frame:
    Hex value: 0x0000
    Hex value :0x02a2
    Hex value :0x0024
    Hex value :0x018c
    Hex value: 0x00ff
    Address 07: control head
    1 fault found :
    01317- control module in instrument cluster (j285)
    004- no signal /communication - Intermittent
    Freeze Frame :
    Fault Status :00100100
    Fault Priority :5
    Fault Frequency :1
    Reset counter :104
    Mileage :296862 km
    Time Indication: 0
    Date :2006.05.09
    Freeze Frame :
    Bin.bits: 10
    Address 61: battery regulator
    Has some quiescent current faults (i had a battery die on me recently)
  1. Battery problem now getting a tapping noise on passenger side from engine.
    By Suejohnhow in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 01-02-2017, 09:08 PM
  2. V5 20v engine noise on chain side of engine
    By craig-v5-20v in forum Toledo
    Last Post: 09-01-2015, 11:33 AM
  3. Please Help Oil Leak From Side Of Engine
    By MAF72 in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2013, 04:50 PM
  4. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  5. loss of diesel from lh side of engine
    By strof in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2008, 08:04 PM
