Thread: Vw passat 55 reg - oil pressure light on and brakes are not working
Results 1 to 10 of 10
  1. Exclamation Vw passat 55 reg - oil pressure light on and brakes are not working
    Sep 2017
    ASHFORD, LONDON
    Hi every one, my 55 plate 2.0 140 has just come up with this oil pressure problem and Stop Engine" and a red symbol of a dripping lamp has come on as well. The manual says check oillevel, which is ok.
    After driving another 10 miles with oil pressure lights on (travelling back home from work) Brakes were getting hard when driving under 5-10 mph, had taken to the garage and he did some checks and advised it needs a new engine,
    Is this really the case or it could be something else.
    Any help would be appreciated.
    Vinay
  2. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    Oil pump failure, why did you drive it with no oil pressure?
  3. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    May 2012
    Everywhere
    308 Post(s)
    Another member of the 77mm Club .
    STOP LOW OIL PRESSURE .
    So S T O P...
    Incrediblely well known oil pump drive engineering issue .
    A 2nd hand engine will still have the same issue , guess the turbo is goosed too .
  4. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Yes - it needs a new engine, finding a good used one that doesn't have this latent 2.0 litre oil pump problem will be tricky, in reality probably going to cost more than the car is worth, unless you DIY. Brakes coming on was probably engine seizing up.
  5. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    11 Post(s)
    *shakes head* What a waste. It’s surprising how many times I read posts like this where people are “so I decided to drive with it on” and then write their car off, If the road said STOP no road ahead! You wouldn’t just carry on driving.... Feel for you though man. It’s horrible having something catastrophic wrong with your car when you rely on it. Another reason I wouldn’t consider giving up my B5.5 for a B6...
  6. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    Sep 2017
    ASHFORD, LONDON
    thanks for your reply.
    I only drove about 10 miles from my work to home and then to nearest garage but when i checked the oil with dipstick, the oil was okay.
  7. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    May 2012
    Everywhere
    308 Post(s)
    Oil level will be fine , it's the oil pump drive , it stops pumping and your engine can die as could a person with a heart attack.
  8. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    Oil level was fine but to oil pump drive broken - no oil pressure
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  9. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    Jan 2013
    109 Post(s)
    Quote Originally Posted by Vinay17 View Post
    You've killed it. Sorry, but that was what the warning lamp tried to warn you. To be fair though, sudden loss of pressure may of wrecked it anyway but trying to drive it for 10 miles just made sure you hammered a stake through its heart.
  10. Re: Vw passat 55 reg - oil pressure light on and brakes are not working
    Sep 2017
    hartlepool
    Oil pump i work in a motor factors and we get these calls all the time around the 2005 -2007 quite common on these years, I dont understand why you drove it 10 mile after tho as you have caused more problems to it you could rebuild your engine with a good mechanic and a week without the car rough cost around £500 new oil pump and chain kit timing belt kit aux belt oil and filter few gaskets but i would get the engine checked out to see if its seized first then go from there
  1. Oil pressure light not working after self test
    By aliw in forum Touran - Sharan - Caravelle
    Last Post: 06-10-2014, 05:50 AM
  2. Replies: 11
    Last Post: 12-07-2014, 10:44 AM
  3. oil pressure warning light passat 1.8t
    By passahat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2010, 12:23 PM
  4. Question passat 1.8t rear fog light not working
    By masterjoey in forum New Member Introductions
    Last Post: 17-02-2009, 10:25 AM
  5. my oil pressure light flashes and rev counter has stoped working
    By DUBTUB in forum Golf MK3 - 1993 - 1999
    Last Post: 21-10-2007, 07:26 AM
