Thread: Audi d3 exhaust gas temp sensor fault code advice
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Audi d3 exhaust gas temp sensor fault code advice
    1840 Post(s)
    Strange that being on factory back order.
  2. Re: Audi d3 exhaust gas temp sensor fault code advice
    May 2017
    GB
    Received it the other day. Thanks Again
    Sent from my SM-N950F using Tapatalk
  3. Re: Audi d3 exhaust gas temp sensor fault code advice
    May 2017
    GB
    So Finially got round to taking it to the garage to have it replaced. The guy there said he needs to take off subframe etc to access it and to replace it.
    Does this sound right? Do you have a installation guide at hand?
  4. Re: Audi d3 exhaust gas temp sensor fault code advice
    1840 Post(s)
    Yes because it is above the down-pipe and that will probaly have to come off for access and removing the down-pipe means lowering the subframe. I had to do an EGT sensor on an AllRoad 4B 2.7T and it would not come out' it stripped itself in the boss so the pipe and turbo had to come out and that means removing the engine.....
  1. Fix Audi code 01032 Exhaust Gas Recirculation Sensor B & 01027 Exhaust Gas Rec Circuit
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2017, 02:57 PM
  2. Audi A4 B8 2.0Tdi Exhaust Gas Temp sensor
    By aaron.ivory.31 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2015, 12:22 AM
  3. EML light on and fault code 005212 - Exhaust Gas Temperature Sensor 3
    By Scottiedogg in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-01-2013, 09:56 PM
  4. Exhaust Gas Temp Sensor
    By Dougster67 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-09-2011, 05:07 PM
  5. URGENT HELP - exhaust/NOX/Gas temp sensor
    By lyndon79 in forum New Member Introductions
    Last Post: 14-12-2009, 03:20 PM
