Thread: Change thermostat as part of timing belt change?
  1. Change thermostat as part of timing belt change?
    Sep 2008
    6 Post(s)
    I'm going to get the timing belt and water pump done on my B8.5 2.0TDI (155PS). It's 5 years old on 42k miles.
    What's everyone's thoughts on doing the thermostat too? On my old B5 Amtrak locomotive V6 the thermostat was buried deep in the engine so it was considered common practice to replace rather than risk it failing given the labour involved to strip it down.
    Audi have special deal on just now during September, so all in 623 including VAT. That's timing belt, water-pump and thermostat.
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  2. Re: Change thermostat as part of timing belt change?
    Sep 2017
    Latvia
    Hi! Thermostats usually are meant to last engines's lifetime, so I can't recommend to change it for sure. If you use proper antifreeze and change it regulary, the thermostat will probably never go bad. If you still want to change it, then use only the OEM part. To exchange it with some aftermarket one is not recommended. Also, can't tell you for sure how hard is to change the thermostat, but for 2.0 TDI it is probably much more easy because it is R4 engine and not a V6. The thermostat's OEM part number is 03L121113A.
  3. Re: Change thermostat as part of timing belt change?
    Nov 2010
    Shetland & S.Tyneside
    103 Post(s)
    IIRC there's two stats on those 2 litre CR engines, one is inside a hose and one on the engine. At 5 years old I'd leave it alone unless it is an insignificant cost when rolled into that service price or you suspect it is playing up. I changed mine earlier this year on my 12 year old pd engine as it had got a bit sluggish to close and was running the engine a bit cool but it hadn't failed completely.
  4. Re: Change thermostat as part of timing belt change?
    Sep 2008
    6 Post(s)
    Thanks for the replies. Audi were quoting 80 odd for thermostat(s)... so I'm thinking that's a hell of a thermostat, so possibly it was for the two? I'll leave well alone then given it sits at 90 degrees.
    I'd only fit genuine parts regards thermostats.
  1. 2.0 TDI Timing Belt Change
    By smoggyrich in forum Golf MK5 - 2004 - 2009
    Last Post: 12-03-2013, 12:51 AM
  2. timing belt change
    By davidfbmw in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-04-2012, 06:53 PM
  3. How Do I change the timing belt on my 04 TDI
    By intertav in forum Golf MK5 - 2004 - 2009
    Last Post: 29-09-2009, 06:15 PM
  4. Question Cam/Timing belt change on a 2.4 V6 '04 A4 Cab...
    By ChrisPovey in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-06-2009, 09:36 AM
  5. timing belt change
    By 9813gray in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2008, 11:33 AM
