Thread: MMI 3 Disc Update
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
  1. Re: MMI 3 Disc Update
    #21
    Aug 2010
    maidstone
    25 Post(s)
    lol, yes, I get that, I too have read so many things on this, and other Audi subjects I do believe I am none the wiser with any of them
    Im a techy (IT) guy so Ill give it a go
  2. Re: MMI 3 Disc Update
    #22
    East Kent
    Quote Originally Posted by spottedhaggis View Post
    I'm an IT techie too.
    Don't suppose you can go through the 'Red Menus.txt' I appended to an earlier post to see what devices you've got?
    If you go to each device, note the Devicename and SW-Index and insert it as a new post, I can work out what levels you'll get off the 5150/5570 set.
  3. Re: MMI 3 Disc Update
    #23
    Aug 2010
    maidstone
    25 Post(s)
    I remember seeing your post, and while I was in traffic in Paris I took pictures of them all, lol, how truly sad is that.
    Ill find them and throw them up a little later
  4. Re: MMI 3 Disc Update
    #24
    Nov 2016
    england
    33 Post(s)
    Yeah on the version you are running you won't need the first disc but yes there is earlier versions on a6 mmi systems mine was at 4220 and I've seen much older versions, not sure if it would come up as invalid disc but your version isn't too much of a big jump, you also only need disc two with certain bluetooth modules (not sure if it's one type or two) but if you do run disc two make sure you run it twice as it wipes it the first time and loads it on the second time, yes it's not massively easy to get from a main dealer but is possible and you can ask for postage I got offered postage for 3 quid but by coincidence I was driving past the dealers the day it got delivered so picked it up, and run the engine while updating or the second spin of disc two will kill your battery (second time takes much longer)
  5. Re: MMI 3 Disc Update
    #25
    Aug 2010
    maidstone
    25 Post(s)
    I have 4 pics of the information on the display.
    Devicename:TUNER EU/US/...
    SW-Number:4E0910541C
    SW-Index:0290
    SW-Date_19-12-03
    HW-Number:????
    HW-Index:H41
    Devicename: DSP-High C6
    SW-Number:4F5910223B
    SW-Index:0220
    SW-Date:23-04004
    HW-Number:4F5034223C
    HW-Index: H14
    Devicename: TELEFON EU
    SW-Number:4E0910333D
    SW-Index:0650
    SW-Date:24-02-04
    HW-Number:.????
    HW-Index: H36
    Devicename: Interfacebox
    SW-Number:4F0910729Q
    SW-Index: 0500
    SW-Date:25-03-04
    HW-Number: 4E0035729
    HW-Index: H43
    ANy use? If I missed anything let me know and Ill get them tomorrow on the ferry :-)
  6. Re: MMI 3 Disc Update
    #26
    Nov 2016
    england
    33 Post(s)
    SW-Index:0290
    SW-Date_19-12-03
    HW-Number:????
    HW-Index:H41
    SW-Index:0220
    SW-Date:23-04004
    HW-Index: H14
    SW-Index:0650
    SW-Date:24-02-04
    HW-Number:.????
    HW-Index: H36
    SW-Index: 0500
    SW-Date:25-03-04
    HW-Index: H43
    You may not need the bluetooth disc... I'm not too sure what telefon Eu is mine was listed as handyvorb (handyvorb 2 I think) in the hidden red menu which is one that did need updating sorry I can't help any further with that one maybe Google telefon Eu see what comes up?
  7. Re: MMI 3 Disc Update
    #27
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by Nard666 View Post
    Unfortunately I'm nowhere near my car at the minute to go through my menu's for you but I should be able to tomorrow at somepoint
  8. Re: MMI 3 Disc Update
    #28
    May 2014
    Darlington
    78 Post(s)
    Telefon Eu is the old Motorola module which uses the Audi handset, that pairs to the unit VIA bluetooth. However only the Audi handset can communicate to the Motorola module.
  9. Re: MMI 3 Disc Update
    #29
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by B5NUT View Post
    Ah I see, would I then be correct in thinking this guy won't need disc 2 of the update set (5570)?
  10. Re: MMI 3 Disc Update
    #30
    May 2014
    Darlington
    78 Post(s)
    Cannot remember, it's so old and useless, it's not worth updating. I would either stick an optical bypass or replace with a normal BT module.
  1. Question Disc Satnav update
    By Boy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2015, 07:40 AM
  2. Sat Nav update Disc
    By DrNorthy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-12-2014, 11:14 AM
  3. Question 302mm disc to 330mm disc upgrade?
    By joedredd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-09-2014, 10:14 AM
  4. MMI HIGH update 3 disc set
    By dave798 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-04-2011, 10:35 PM
  5. Sinking pedal after disc change Update
    By Chappers in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-02-2011, 10:19 PM
