Thread: Mk4 golf major idle issue
  1. Mk4 golf major idle issue
    Sep 2017
    London
    Hi guys need your help.
    So ive been given a 99 golf and told if i can fix it i can keep it. So my issue is it has a major idleing problem where it bounces from 1000 to 2000
    Constantly.
    So work done before i started new maf sensor new crank sensor new cam sensor. I noticed it had a moajor misfire so changed coil leads and plugs misfire sorted but still iratic idle have cleaned throttle body still the same also the exhaust glows red hot?
    The throttle body also pops when accelerating any help and advice guys?
  2. Re: Mk4 golf major idle issue
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I'd get a compression test done next, suspect a burnt out valve.
  3. Re: Mk4 golf major idle issue
    Bristol
    A mate had a similar issue with a focus, turned out the cat collapsed , blocking the escape of gases and causing the exhaust to get very hot,,,,,
    MK5 Golf TDI 2.0ltr GT Sport in Black
  4. Re: Mk4 golf major idle issue
    Nov 2010
    104 Post(s)
    Good point - loads of exhaust back pressure.
    Quote Originally Posted by cbrpaul View Post
  5. Re: Mk4 golf major idle issue
    Jul 2007
    glasgow
    35 Post(s)
    or a collapsed baffle in an exhaust
    take off cat & have a look , or disconnect exhaust at exhaust manifold and turn her over and apart from lots of noise ...................... does it help ?
  1. Replies: 1
    Last Post: 09-06-2011, 03:10 PM
  2. Golf mk4 tdi pd150 idle issue.....
    By bust150 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-02-2010, 07:12 PM
  3. Please Help New to forum with major issue
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-01-2010, 06:17 PM
  4. Please Help Golf GTi 8V - Idle Issue
    By svenandnancy in forum Golf MK3 - 1993 - 1999
    Last Post: 13-07-2009, 11:49 AM
  5. Major Fuel Issue
    By vaslam1986 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2007, 02:13 PM
