My car started loosing all of the coolant as it reaches operational temperature. It suddenly just started today. I have located plastic part from where coolant is running down and steam coming out too.
Please help me identify what is this part by pictures.
3.jpg - Google Drive
2.jpg - Google Drive
1.jpg - Google Drive
Vag com codes are
VAG-COM Version: Release 409.1-S
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
**Controller: 06A 906 033 AF
**Component: SIMOS33 1.6l 2V 00AT4083
**Coding: 00033
**Shop #: WSC 01271
**WVWZZZ1JZ2W481205 ****VWZ6Z0A3820669
2 Faults Found:
16706 - Engine Speed Sensor (G28): No Signal
***********P0322 - 35-10 - - - Intermittent
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
***********P1290 - 35-00 - -
Readiness: 0010 0001
Address 02: Auto Trans
**Controller: 01M 927 733 JH
**Component: AG4 Getriebe 01M ***4830
**Coding: 00000
**Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes
**Controller: 1C0 907 379 J
**Component: ABS FRONT MK60 *****0103
**Coding: 0001025
**Shop #: WSC 01271
1 Fault Found:
01314 - Engine Control Module
***********013 - Check DTC Memory - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
**Controller: 1J0 920 806 C
**Component: KOMBI+WEGFAHRS. RB8 V17
**Coding: 03722
**Shop #: WSC 00000
Address 19: CAN Gateway
**Controller: 6N0 909 901
**Component: Gateway K<->CAN ***0001
**Coding: 00006
**Shop #: WSC 01271
Address 46: Central Conv.
**Controller: 1C0 959 799
**Component: 1Z Komfortgerát HLO 0001
**Coding: 00259
**Shop #: WSC 01271
1 Fault Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
***********27-00 - Implausible Signal
End **--------------------------------------------------------------------------------------------------
