Thread: Fuel Filter change 2005 2.0 L TDI 140 GT
  1. Fuel Filter change 2005 2.0 L TDI 140 GT
    Aug 2017
    GB
    Well thanks to the help from this forum, I managed to do the timing belt, a bit awkward with little room, but with a bit of patience it was all good.
    I thought I would do all the filters and oil at the same time.
    But when changing the the fuel filter, I forgot to prime. It ran perfectly for a short time than cut out. So I opened the fuel filter housing and primed it but it still won't start.
    What is the best way to purge it, tow it and bump start it?
    I had this happen on a Ford diesel van , and the only way I got it to start was to tow it and bump it.
    All help much appreciated by this relatively new member.
    Many thanks.
    Sent from my E5823 using Tapatalk
  2. Re: Fuel Filter change 2005 2.0 L TDI 140 GT
    Jan 2013
    bridgend, south wales
    This happened to me once and cycling the ignition 5 or 6 times was enough to sort it out as the pump primes the lines with ignition on - just turn ignition on for a few seconds until you hear the pump under the back seats stop and then repeat
    Hope that helps
  3. Re: Fuel Filter change 2005 2.0 L TDI 140 GT
    Aug 2017
    GB
    Thanks James, that's what did and it fired into life slowly, it's running fine now.
    Thanks again.
  1. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  2. 130 pd fuel filter change when?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-01-2011, 12:15 AM
  3. fuel filter change
    By ad777 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2010, 07:10 PM
  4. Fuel filter change
    By NICK H in forum Octavia
    Last Post: 14-05-2010, 01:03 PM
  5. fuel filter change
    By mf6480 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2009, 06:14 PM
