Thread: P0243
  1. P0243
    Jul 2008
    Lisburn
    15 Post(s)
    Just before i splash out on £50 i wanted to confirm that the above code can be the result of what the VAG boys know as N75, in my case 1K0906283A solenoid valve, and i am not barking up the wrong tree.
    edit EGR solenoid valve that is
    the glow plug light will flash and there will be no boost, normally happens when hot, sometimes will recover itself.
    Thanks,
    Stewart
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  2. Re: P0243
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    what engine have you got? 2007 car, is it pd or early common rail? could be N75 or sticking VNT guidevanes, a bit more than 50 quid worth.
  3. Re: P0243
    Jul 2008
    Lisburn
    15 Post(s)
    Thanks for the reply, its an ASB engine, not sure which it is as I am still learning with this car.
    It started to play about and I got the carbon clean done, good job, a lot more responsive, and returning more MPG.
    I used to get between 150 and 180 miles from 30 liters of fuel, now its normally above 200 and I seen 240 the last time.
    But the problem didn’t really change now getting more frequent.
    Thanks,
    Stewart
  4. Re: P0243
    Jul 2008
    Lisburn
    15 Post(s)
    OK so changed the exhaust valve, didnt fix it but changed it a bit.
    It has also thrown up a P0046 and i found this:- Audi a6 3.0tdi actuator issue - YouTube
    I know i should really have a scan but i see it as more of a challenge, and a scan could lead me down the wrong way very quick. I am due to get an OBDelevn in the post so will see how that goes.
    both exhaust and turbo actuator seem to have full and free movement.
    i am not thinking the turbo actuator as the glow plug light can come on when sitting at a red light, and she can loose power without the light on also.
    A simple shut off and re-start will also fit it in both cases, i have done this will driving ( private road of course) so was doing about 40 ish and able to put power down straight away, with no issues... so that tells me not something sticky?
    thanks for watching...
    Stewart
  5. Re: P0243
    Jul 2008
    Lisburn
    15 Post(s)
    got an obdeleven, quick play seems to be a good tool, lots of historic ( i hope) faults ref dodgy relay, so i cleared and will read again for true reading. the one for the engine threw these up :-
    System description: 3.0L V6TDI G000SG
    Software number: 4F0910409A
    Software version: 0010
    Hardware number: 4F0907401C
    Coding: 0011312
    Trouble codes:
    P3348 - Activation for exhaust turbocharger 1 control unit Electrical error in circuit mechanical malfunction
    Intermittent
    P3348 - Activation for exhaust turbocharger 1 control unit Electrical error in circuit Short circuit to B+
    Intermittent
    P1653 - Read DTC memory of ABS CM Lower limit not reached
    Intermittent
    from that i found this...
    3.0 tdi Limp mode - new actuator controller and turbo clean - flashing glow plu | Audi-Sport.net
    ill keep this up to date hopefully help someone down the line
    Stewart
