Thread: Varying brake pedal
  1. Varying brake pedal
    Feb 2011
    Sutton Coldfield England
    Sometimes when driving and braking my brake pedal goes hard with slightly less travel and it's very assuring
    Other times the pedal is 'normal' - slightly softer but effective
    cant understand what might cause this or whether it's how it's meant to be
    any suggestions please
    bibh
  2. Re: Varying brake pedal
    Nov 2008
    Cramlington,Northumberland
    9 Post(s)
    You don't mention your vehicle type, but more than likely a Servo issue. Check vacuum pipe to it and also check for water lying in Plenum chamber due to blocked drain.
    Alan.
    APR ST1
  3. Re: Varying brake pedal
    Feb 2011
    Thanks Alan02
    As you say it may be servo but not sure how to confirm this
    my car A6 C5 Sport 2004 model V6 Multitronic
    Thanks Bobh
  4. Re: Varying brake pedal
    Nov 2008
    9 Post(s)
    Engine off, pump brake pedal repeatedly until pedal feels solid when pressed. Keep foot on pedal and start engine. Pedal should sink a few inches. You should hear a hiss when pressing pedal. If you have a vacuum pump or hose issue to the servo you will be losing essential vacuum from the servo to operate. Blocked drain grommets in the area of the servo cause water build up which ruins the servo and electrics, so check for pooling water also.
    Alan.
    APR ST1
  5. Re: Varying brake pedal
    Feb 2011
    Thanks Alan but I'm a bit confused between what should happen when I depress the pedal and what shouldn't happen
    can you give me the two scenarios separately please
    Bobh
  6. Re: Varying brake pedal
    Nov 2008
    9 Post(s)
    Engine running you have vacuum so pedal will sink a few inches before going solid.
    Engine off, pump pedal a few times then press hard.... pedal will feel solid at top end of travel, no vacuum present.
    If this is like yours that is normal scenario.
    Alan.
    APR ST1
  7. Re: Varying brake pedal
    Feb 2011
    seems I have the ‘normal’ scenario but it still seems strange to me on occasions
    Bobh
  1. Replies: 4
    Last Post: 30-05-2016, 12:21 AM
  2. Please Help Brake pedal spongy, hissing when depressing pedal
    By The Norwegian in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2016, 11:09 PM
  3. The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    By mebedforduk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-08-2012, 09:34 AM
  4. Replies: 6
    Last Post: 27-09-2011, 07:49 PM
  5. Tickover varying
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-01-2008, 06:35 PM
