Thread: Battery charging
  1. Battery charging
    Sep 2010
    LEEDS UK
    Because the car is used infrequently, I connect a CTEK battery charger when the car is in garage. I usually leave the bonnet slightly ajar to accommodate the leads.
    This of course activates the bonnet open switch, which I assume prevents the electrical system going into sleep mode.
    Is it preferable to completely close the bonnet, and allowing sleep mode or will it make no difference.
  2. Re: Battery charging
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Car won't go into sleep mode so will be using a small part of the charge. There will be a way to route the charger cables so that you can shut the bonnet and lock the car.
    Mad Mitch
  3. Re: Battery charging
    Apr 2007
    France
    12 Post(s)
    I take mine out the front, over a headlight at the pointy bit at the top of the wing.
    1996 Laguna 2.2D
    1977 MGB roadster
  4. Re: Battery charging
    Sep 2010
    LEEDS UK
    Thanks, I have made an extension using a flat cable. I can now route same as QUATRELLE, and keep bonnet closed.
  5. Re: Battery charging
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    If you're charging a battery in the garage. why would you be concerned about current drain caused by the bonnet not being closed fully ? The charger output would be many times any small current drain.
    Skoda Octavia II SE 1.9PD TDI
  6. Re: Battery charging
    Sep 2010
    LEEDS UK
    More academic, was attempting to find out if not entering sleep mode had any detrimental effects.
  1. Battery Charging
    By Schmittster in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-01-2014, 02:01 AM
  2. Replies: 4
    Last Post: 01-06-2013, 03:49 PM
  3. Battery charging
    By FIBAMAN in forum Jetta MK3 - 2005 - 2013
    Last Post: 03-12-2010, 09:15 PM
  4. Please Help battery light not working and battery not charging
    By nomanjuice in forum Polo - Derby - Lupo - Fox
    Last Post: 20-05-2010, 07:25 AM
  5. Please Help Battery charging
    By davec573 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-09-2009, 08:00 PM
