Thread: Low Oil Pressure warning - Intermittent
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 61
  1. Re: Low Oil Pressure warning - Intermittent
    #21
    May 2012
    Everywhere
    308 Post(s)
    Yes , whole oem 77mm module £1200+ still faulty .
    Chain driven upgraded chain and tentioner using better quality parts £240+ but better to convert for £625 to aftermarket geared module as includes 100mm .
    Chain to 100mm geared aftermarket remanufactured modified whole module £625+ .
    Aftermarket remanufactured modified 100mm chain or geared balancer shaft kit £215 + .
    + labour any tools , sealant , oil change etc .
  2. Re: Low Oil Pressure warning - Intermittent
    #22
    Sep 2017
    Plymouth, Devon
    Thanks for all your help here, sorry if I'm asking stupid questions... but I'd never heard of a balancer shaft until I Googled "Audi A6 oil pressure"
    Chances are then... I can get the 100mm kit that you provided a link to earlier and get my garage to install that on my existing gear driven module? Or as I'm having oil pressure issues is it likely to need the whole module replacing?
  3. Re: Low Oil Pressure warning - Intermittent
    #23
    Sep 2008
    chester
    17 Post(s)
    These balance shafts counter rotate at twice engine speed so the little key shaft has a hard time,you should have the geared set up already installed so its just a matter of a re- engineered shaft(just the one) with a longer key way (if it is no pressure).
  4. Re: Low Oil Pressure warning - Intermittent
    #24
    Sep 2017
    Plymouth, Devon
    Quote Originally Posted by Gazwould View Post
    @Gazwould, do you know where I can purchase the entire thing from? I think I might have my garage in a position where they are prepared to pay to have the whole assembly replaced, but I don't want them to fit the one that will still have the same problem again later!
    By the sounds of what you've said, I can purchase (for around £625) a geared balancer shaft module, that will be compatible with my car, and will use the 100mm part...?
  5. Re: Low Oil Pressure warning - Intermittent
    #25
    Sep 2017
    Plymouth, Devon
  6. Re: Low Oil Pressure warning - Intermittent
    #26
    May 2012
    Everywhere
    308 Post(s)
    You do not need a whole module and best stick with well known British .
    Kit 9 £215 .
  7. Re: Low Oil Pressure warning - Intermittent
    #27
    Sep 2017
    Plymouth, Devon
    Ideal, cheers. I'll suggest that kit to my garage then. I saw on that link for the whole article that they should check for damage to the main crankshaft bearing ... necessary you think?
  8. Re: Low Oil Pressure warning - Intermittent
    #28
    May 2012
    Everywhere
    308 Post(s)
    Turbo is first to suffer damage .
  9. Re: Low Oil Pressure warning - Intermittent
    #29
    Sep 2017
    Plymouth, Devon
    So safe to work on the assumption that if the turbo is OK that it hasn't caused any fatal damage?
  10. Re: Low Oil Pressure warning - Intermittent
    #30
    May 2012
    Everywhere
    308 Post(s)
    Probably if switched off early enough .
    My father drove a few miles and I don't know how he got away with it , towards the end the turbo was consuming oil and required a new turbo so px'd .
  1. Replies: 28
    Last Post: 20-09-2023, 01:39 PM
  2. A6 3.0tdi quattro Oil Pressure Switch Intermittent fault
    By viperjng in forum 3.0TDi - Engine
    Last Post: 01-06-2016, 03:47 AM
  3. Intermittent Oil warning light
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2010, 07:40 PM
  4. Replies: 4
    Last Post: 21-07-2010, 09:10 PM
  5. Intermittent Oil Warning
    By richjthorpe in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-04-2007, 10:30 PM
