Thread: Brake pad warning light fault
  1. Brake pad warning light fault
    Dec 2010
    glasgow
    A few months ago my brake pad warning lamp would come on intermittently. Now its on all the time.
    My local Indy said my brakes are fine but the front and rear nearside wiring looms both need replacing.
    He states its common on the C7 as they draw up moisture like a straw causing the wires to corrode all the way up. Its about 70 quid for each loom repair kit plus 4 hours labour.
    My question is would it be worth spending the money only for the same thing to happen again or could the light be coded out using a VAGCOM? The car has only done 40,000 at 4 years old.
    A6 C7 S line
  2. Re: Brake pad warning light fault
    Mar 2013
    Reading
    31 Post(s)
    Quote Originally Posted by vwhighline View Post
    If I were you, I'd actually do new brake pads all around that come with new sensors for just a few quid more...
    Sent from my mobile...
  3. Re: Brake pad warning light fault
    Sep 2008
    chester
    17 Post(s)
    They're quoting you for the looms back to the car not her small one's on the pads,If I was you I would unplug them 1 at a time put a jumper on the terminals and see which one is giving the problem,they can't all go at once.
  4. Re: Brake pad warning light fault
    Jul 2013
    Yorkshire
    18 Post(s)
    As above, I would check the sensors on the brake pads themselves first. This can be done even without the wheel off, just jack up. If your car is like mine, there is only 1 sensor on each axle. The way they are routed and located it's very likely to be one of the wires that has broken. Only 1 has to be worn through to light the light up. They can be replaced without taking pads out. Putting a jumper across the plug terminals on the car side is a good idea. if no light = sensors, if still light = loom.
    The sensors sit around the back of the calliper on the top of the back pad; think they are both nearside if I remember correctly.
  1. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  2. ABS warning and Brake Red Warning - power supply fault??
    By martink in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-06-2009, 10:58 PM
  3. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  4. Brake warning light fault Passat
    By mikeybarvas in forum Passat - Archive Topics
    Last Post: 19-12-2007, 10:01 AM
  5. Brake fault warning light
    By short shift in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-09-2007, 08:16 PM
