Thread: 1.6 Tdi - Fans always on, DPF problem???
Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
  1. Re: 1.6 Tdi - Fans always on, DPF problem???
    #31
    Dec 2016
    did I say I know more than you? did I say you ALL diesels would be like that? NO ... Come finger my tailpipe if that's what you're into, you'll get dirty black fingers and as I've said.. it still has both its EGR and DPF.
    Would've expected a more intelligent response from a forum moderator, rather than the childish I know more than you how dare you question me **** swinging contest.. grow up.
  2. Re: 1.6 Tdi - Fans always on, DPF problem???
    #32
    1840 Post(s)
    Quote Originally Posted by JLawson90 View Post
    Not in some many words but saying
    but this is a load of a rubbish..
    Is a sweeping statement and rude....
    We have serviced two DPF cars today, an A1 1.6 TDI and a Golf 7 2L BM and both had perfectly clean tailpipe internals. I'll maintain my stance that if your car is an EU5 DPF and if the tailpipes are black inside, then the DPF is not working as it should, if at all.
  3. Re: 1.6 Tdi - Fans always on, DPF problem???
    #33
    Dec 2016
    you say my reply is a sweeping statement, when in fact your original post of saying it's easy to tell if a car doesn't have a DPF, because the tailpipes will be black.. is a hell of a lot more sweeping.
    If it wasn't working I'm pretty sure I would have some problems, and it wouldn't have just went through a successful regen the other week like it did
  4. Re: 1.6 Tdi - Fans always on, DPF problem???
    #34
    1840 Post(s)
    It isn't at all sweeping from my perspective as it is based on multiple observations of hundreds of cars over nearly a decade of servicing and repairing VAG vehicles fitted with a DPF. However your observation was based on one example. As I said, not working as it should, if at all. If soot deposits are left inside the tailpipe to any degree, it means the DPF is not as effective as it should be but does not mean it is not working.
  1. Question 2005 1.6 FSI - Cooling Fans and Temperature Sensor Problem
    By Peter OJ in forum Golf MK5 - 2004 - 2009
    Last Post: 13-06-2016, 02:02 PM
  2. 2.0 TDI 170 - AC and Fans problem
    By lgd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-03-2015, 08:32 PM
  3. Problem with cabin fans
    By toby01 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-06-2011, 09:49 PM
  4. Mk5 2007 Golf Gti Fans Problem
    By shizy01 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-10-2009, 09:01 PM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
