Thread: 1.6 Tdi - Fans always on, DPF problem???
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. Re: 1.6 Tdi - Fans always on, DPF problem???
    #21
    1840 Post(s)
    If the coil light came on there must be fault codes, what are you checking the memory with?
  2. Re: 1.6 Tdi - Fans always on, DPF problem???
    #22
    Sep 2017
    Tyrone
    Checking it with Vcds but nothing there, my mechanic has autel diagnostics and nothing there either!
  3. Re: 1.6 Tdi - Fans always on, DPF problem???
    #23
    Sep 2017
    Tyrone
    Forgot to say, I done about 50 miles in it today and it feels like its driving fine again, obviouly there is something intermittent wrong with it....
    I noticed it returning around 50 MPG but on the same run before it usually returned over 60 or close to it (I wasnt driving it hard either)
  4. Re: 1.6 Tdi - Fans always on, DPF problem???
    #24
    Sep 2017
    Tyrone
    Bump, still havent got this sorted!
  5. Re: 1.6 Tdi - Fans always on, DPF problem???
    #25
    Sep 2017
    Tyrone
    Quote Originally Posted by DMcCo View Post
    Have change coolant temp sensor, coolant flange, secondary water pump, main water pump changed again, radiator flushed etc
  6. Re: 1.6 Tdi - Fans always on, DPF problem???
    #26
    Dec 2014
    Bedford
    42 Post(s)
    Unlikely to be any of them. Which is it being activated from ac or engine cu.
  7. Re: 1.6 Tdi - Fans always on, DPF problem???
    #27
    1840 Post(s)
    And the engine warning light is still on?
  8. Re: 1.6 Tdi - Fans always on, DPF problem???
    #28
    Dec 2016
    it's easy to tell if a DPF is there, the tailpipes are spotless.
    old thread I know, but this is a load of a rubbish.. fair enough if the car is new, my passat has done 116k miles fully standard (EGR & DPF) and the tailpipes are black as can be (inner anyway, i clean the outters)
    0 0 1
  9. Re: 1.6 Tdi - Fans always on, DPF problem???
    #29
    May 2012
    Everywhere
    308 Post(s)
    True , a dpf equipped car can still blow 2.00 on the first acceleration .
  10. Re: 1.6 Tdi - Fans always on, DPF problem???
    #30
    1840 Post(s)
    Quote Originally Posted by JLawson90 View Post
    Don’t spare my feelings will you, just wade in there throwing punches, we’ll this is what I think
    How many DPF equipped VAG products did you service this week and stick your finger up the tailpipes and sniff the exhaust of with it six foot up in the air? Personally (with two mechanics off) this week I did two a day so maybe I have a smidgein more experience than your good self! By the way, those nine cars and one T5 all had spotlessly clean tailpipe internals although the Sharan 2 and one of the Audi A6’s were EU6 Add Blue models so you would expect it. Two fingers sir!
  1. Question 2005 1.6 FSI - Cooling Fans and Temperature Sensor Problem
    By Peter OJ in forum Golf MK5 - 2004 - 2009
    Last Post: 13-06-2016, 02:02 PM
  2. 2.0 TDI 170 - AC and Fans problem
    By lgd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-03-2015, 08:32 PM
  3. Problem with cabin fans
    By toby01 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-06-2011, 09:49 PM
  4. Mk5 2007 Golf Gti Fans Problem
    By shizy01 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-10-2009, 09:01 PM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
