Thread: 1.6 Tdi - Fans always on, DPF problem???
Results 11 to 20 of 34
  1. Re: 1.6 Tdi - Fans always on, DPF problem???
    1840 Post(s)
    A reputable company is one that does not break the law....
    0 2 0
  2. Re: 1.6 Tdi - Fans always on, DPF problem???
    Nov 2013
    Stoke on Trent
    Yes it's breaking the law Crasher, but i presume there will always be companies out there providing this service.
  3. Re: 1.6 Tdi - Fans always on, DPF problem???
    1840 Post(s)
    I don't know where it is but three VW mechanic MOT testeres have had their licences suspended for blatantly allowing DPF deleted cars through.
  4. Re: 1.6 Tdi - Fans always on, DPF problem???
    May 2012
    Everywhere
    308 Post(s)
    Must of been a delete pipe ?
  5. Re: 1.6 Tdi - Fans always on, DPF problem???
    Nov 2013
    Stoke on Trent
    Yeah, i thought it was only a visual check for the dpf
  6. Re: 1.6 Tdi - Fans always on, DPF problem???
    1840 Post(s)
    We had a Passat in the other day, the DPF had a big patch welded on the bottom, MOT man said no no. Anyway, it's easy to tell if a DPF is there, the tailpipes are spotless.
  7. Re: 1.6 Tdi - Fans always on, DPF problem???
    #17
    Sep 2017
    Tyrone
    About 4 days after getting this done i thought the car felt a bit jerky. coil light came on on the way home, nursed it home and it died out and would only run for 10 seconds max!
    Until today, i put a blank of the egr pipe near the dipstick and it started up straight away! It seemed quite smokey but cleared.
    I then took it out a drive and back to the same thing, going up hills (putting strain on) fans are running and it starts to overheat! feels jerky like it did before when doing a regen but it doesnt idle at 1000rpm now
    I let it cool down and left it back home until tonight i went for a 40 minute drive and it never overheated, but i did hear the fans come on
    What is wrong here? my mechanic doesnt know, person that remapped it doesnt know, im lost!!
  8. Re: 1.6 Tdi - Fans always on, DPF problem???
    #18
    1840 Post(s)
    It has fault codes stored, you need to know wat they are first.
  9. Re: 1.6 Tdi - Fans always on, DPF problem???
    #19
    Dec 2014
    Bedford
    42 Post(s)
    At a guess i would think you have a faulty fan control unit. 4 wires on plug heavy red heavy brown 2 thin wires from memory one is probably yellow and the other red and another colour. Heavy thick wires are obviously live and earth . Yellow will be activated via ac module and the thin red will be by engine control unit. Now you to check which is being activated. To find your answer. But i have found the main fan has its own controller built in that randomly activates itself and the slave fan.
  10. Re: 1.6 Tdi - Fans always on, DPF problem???
    #20
    Sep 2017
    Tyrone
    No fault codes stored as the car died out and when i tried to start it no warning light came on? Still has no lights or codes today when i checked today
    i have a look at the fan during the week cheers
  1. Question 2005 1.6 FSI - Cooling Fans and Temperature Sensor Problem
    By Peter OJ in forum Golf MK5 - 2004 - 2009
    Last Post: 13-06-2016, 02:02 PM
  2. 2.0 TDI 170 - AC and Fans problem
    By lgd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-03-2015, 08:32 PM
  3. Problem with cabin fans
    By toby01 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-06-2011, 09:49 PM
  4. Mk5 2007 Golf Gti Fans Problem
    By shizy01 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-10-2009, 09:01 PM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
