Thread: 2005 A3 Sportback P0226 Error
Results 1 to 10 of 17
  1. 2005 A3 Sportback P0226 Error
    Sep 2017
    Manchester UK
    Hi All,
    I am having an ongoing issue with my 55 plate A3 140 Sportback,
    I am getting a serious lack of power and the only error message I have managed to get is P0226,
    I have had a need turbo in the last 12mths plus a new oil pump, I had a Terraclean in the last month and the EGR was then blacked off, still no power or acceleration anything higher than 2nd gear, there is a complete drop when going up hill,
    I am seriously concerned I will need another turbo but I need to understand what is causing the underboost as the terra clean should have cleaned the system etc
    Please can anybody advise or assist as I have always looked after the vehicle but need to be careful where to invest the pennies.
  2. Re: 2005 A3 Sportback P0226 Error
    Sep 2008
    chester
    17 Post(s)
    Thats the throttle position sensor.
  3. Re: 2005 A3 Sportback P0226 Error
    Sep 2017
    Manchester UK
    Quote Originally Posted by Grimly Fiendish View Post
    Hi All,
    I actually had a new one of those put in by Audi a couple of years ago after the pedal snapped after cleaning the car, am I right in thinking this will require a re map for the replacement to be recognised ?
  4. Re: 2005 A3 Sportback P0226 Error
    Sep 2008
    chester
    17 Post(s)
    Not a remap,what did you use to scan it.
  5. Re: 2005 A3 Sportback P0226 Error
    Sep 2017
    Manchester UK
    Quote Originally Posted by nevo View Post
    It was a Snap On scanner at the terra clean garage, is this sensor located under the peddle ? silly question but I need to be sure as I cannot fine one on the internet for an A3 of my year unless I am searching for the wrong thing, is maybe a Bosch part as I need to fine the correct part number.
  6. Re: 2005 A3 Sportback P0226 Error
    Sep 2017
    Manchester UK
    So the plot thickens, Audi have told me that there is no such thing as a throttle position sensor and what I need is a throttle valve controller which is £404 but before they are prepared to supply it I must have a scan for errors completed first at £98 ph but they would not say how many hours would be required, I have also questioned the length of the warrantee for the new pedal I had fitted as if it is the throttle position sensor it should be covered.
    So I have to ask the question, if the pedal exists so must the sensor ? at which point Audi said there was no record of my car having a accelerator pedal fitted although I have the receipt at home in the filing cabinet.
    I am now considering going to an independent to get the diagnostic done as the code P0266 is not a recognised Audi code apparently.... still no further forward until I can get the diagnostic done tomorrow, (Audi Manchester only run them Mon to Thurs)
  7. Re: 2005 A3 Sportback P0226 Error
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Has anyone checked your MAF sensor or V157 intake throttle valve / anti shudder valve or does your engine have the intake manifold flaps and actuator ( I don't think it does: 2litre pd engine?) , also stating the obvious, have you checked the air filter and changed the fuel filter - did the terraclean guy change the filter or bypass it to add his fluid?
    I'm seeing P0266 as injector#2 fault P0266 - Ross-Tech Wiki, I could be wrong though, if you can find an independent with VCDS they should be able to check.
  8. Re: 2005 A3 Sportback P0226 Error
    1840 Post(s)
    That will usually be the wiring to the throttle pedal but failure of the pedal does happen. The warranty on a genuine part is 2 years on production of the receipt of purchase and they may want to see prooof it was properly installed if they want a reason to wriggle out of the warranty.
  9. Re: 2005 A3 Sportback P0226 Error
    Sep 2017
    Manchester UK
    The Engine is a BKD type according to the information plate, I have no idea about the MAF etc until tomorrow when hopefully I will see some error codes, I have been told this could be as simple as a 10am fuse that has blown but I have checked all these this afternoon and nothing seems incorrect, I understand through reading on this forum the actuator may be held open but I do not want to start poking around until I get the codes read.
  10. Re: 2005 A3 Sportback P0226 Error
    1840 Post(s)
    The fuse idea is related to the V157 fault and this is not the one you have given us a code for
  1. 2005 Sportback 2.0 TDI MPG?
    By danny07 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-01-2016, 06:00 PM
  2. Question Pioneer SPH Da 120 In a 2005 A3 Sportback
    By Mattu64 in forum In Car Entertainment
    Last Post: 15-08-2015, 03:56 PM
  3. Question 2006 A3 1.6 Sportback Error code
    By Greystoke in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-05-2012, 03:38 AM
  4. Question 2006 octavia 1.9 tdi p0226
    By njg in forum Octavia
    Last Post: 27-09-2010, 09:05 PM
  5. 2005 A3 sportback 2.0 TDi
    By tdz840 in forum Audi A3 - Archive Topics
    Last Post: 09-08-2008, 08:13 AM
