Thread: Clutch judder
Results 21 to 30 of 34
  1. Re: Clutch judder
    #21
    Jan 2008
    68 Post(s)
    A colleague of mine has a 17 plate A5 2.0TDi manual with 5k on the clock.
    He has clutch judder. It's not just the A6 it effects.
  2. Re: Clutch judder
    #22
    Dec 2016
    Sussex, UK
    12 Post(s)
    Quote Originally Posted by Renars View Post
    Just stupid by Audi not fixing this problem in FL model, after it was well known in first C7 !
    They have, they stopped selling the manual gearbox version.
    DMF's are notorious for their problems. Ask any taxi driver who drives VW group (or any other group) manual if they have replaced their clutch yet? Most will have and at th esame time replaced the DMF with a solid flywheel. Slightly more vibration at launch but no more failures after a few miles.
    DMFs just make the pull away smoother by cushioning the vibration the engine passes on to the gearbox
  3. Re: Clutch judder
    #23
    Jan 2018
    Sussex
    49 Post(s)
    Replacing DMF with solid flywheel is stupid and I don't care what people who do that kind of things say or think.
    And DMF makes everything smoother while engine is running.
    And they sold manual until the end of A6 C7 !
    And what solid DMF they use for Audi A6 C7 ? From BiTDI ?
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2011 Golf MK6 1.6 tdi CAYC 5 speed
  4. Re: Clutch judder
    #24
    Jan 2013
    Wessex. and Southern France
    61 Post(s)
    But removing DPF is ok though, how strange.
  5. Re: Clutch judder
    #25
    Jan 2018
    Sussex
    49 Post(s)
    Well yes, DPF doesn't make car run any better, gearbox and clutch last longer.
    Sure its bad for out health, but look how many old piece of crap cars without any health concerns are on roads worldwide.
    Current cars:
  6. Re: Clutch judder
    #26
    Jan 2013
    61 Post(s)
    And it's illegal, but never mind, whats a few more dead people anyway.
  7. Re: Clutch judder
    #27
    Dec 2016
    Sussex, UK
    12 Post(s)
    The DMF generally only makes the pull away smoother. once the drivetrain is under load, the flywheel effectively gets stick in one position until the load is removed. It is essentially two solid flywheels joined together with rubber blocks. These rubber blocks can only take so much vibration until they start to break down and the dust contaminates the clutch plates and the starter motor meaning that whenever you replace the clutch on a car these days, unlike before when it was only the clutch and maybe the release bearing, now you change the flywheel and starter motor too to save having to pull it all apart again before the clutch goes again next time.
  8. Re: Clutch judder
    #28
    Jan 2018
    Sussex
    49 Post(s)
    Quote Originally Posted by bbrown1664 View Post
    It helps every time you push and release clutch or push and release throttle.
    It saves gearbox.
    Its not just a rubber blocks but spring system, which actually dampens violent torque variations.
    If it would not be effective it would not be used as car manufacturers are always trying to make things cheaper - look at VW emission scandal for example.
    Problem is there are many reliable DMFs and clutches and also many unreliable.
    C7's manual gearbox combination is one of worst by far.
    Changed DMF for my '06 Passat B6 BMR DSG, payed for new LUK 270 EUR, changed by myself and 30 min help from friend (took 7 hours as I didn't have special tool for pilot bearing)
    Morale - don't buy manual !
    Current cars:
  9. Re: Clutch judder
    #29
    Jun 2013
    Inverallochy, Aberdeenshire
    7 Post(s)
    I had my 2016 A6 in for an Inspection Service yesterday - 19,500 miles and also to investigate the clutch judder. 250 for a pollen filter and the "Inspection" but I figured money well spent to maintain my warranty - which runs until June 2019.
    I was told there is a technical bulletin, and the service agent had it in his hand and was reading from it, and said it's due to moisture, water or oil, and is normal and is nothing to worry about. I thought that is interesting and I'll read it when I get home tonight - but he never put it in with the paperwork.
    On the way home, the judder was worse than it has ever been.
    They will be emailing me on Monday, so I will report the judder is worse and request a copy of the service bulletin - and say I am now aware that this is a common problem with DMF and Audi have stopped the manual box on the A6.
    I bought the car - ex demonstrator - from an Audi Dealer - and it's only ever been serviced by Audi.
    My service history also has never been correct - the service from when I bought it has never showed online when I log in, although the dealer I bought it from, Inverness Audi - insist it is showing on the Audi system. It's also missing from the record Aberdeen Audi gave me yesterday.
    I have the feeling I'll be getting in touch with Audi Customer Service next week.
    2016 Audi A6 C7 - 2.0 TDI Sline Ultra - Moonlight Blue - No Tech Packs
  10. Re: Clutch judder
    #30
    Jan 2018
    Sussex
    49 Post(s)
    Why do people listen to Audi dealer when they are saying something about product they are representing ?
    Clutch judder is uncomfortable and for car such as Audi A6 is absolutely unacceptable !
    Its manufacturers fault and responsibility to deal with it.
    What they are going to say next - because of oil and water and some other stuff loosing brakes on every third push of pedal is also normal ?
    Current cars:
  1. Please Help intermittent clutch judder with new clutch & flywheel
    By FLENG2008 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-01-2013, 03:48 PM
  2. Please Help 2.7 TDI clutch judder
    By gixer1979 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-09-2012, 10:27 PM
  3. Clutch judder or DMF?
    By randall977 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-11-2011, 10:03 AM
  4. clutch judder
    By jamedvickni in forum Golf MK5 - 2004 - 2009
    Last Post: 07-12-2009, 03:22 PM
  5. Clutch judder
    By redkite66 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-10-2009, 11:17 AM
