Thread: mk 4 golf no crank.
  1. mk 4 golf no crank.
    Sep 2008
    chester
    17 Post(s)
    Having a spot of bother with the wifes mk4 tdi agr,battery has been on the edge for some time starts but a bit sluggish,anyway changed over to another one,connects up,come to start,nothing,some head scratching decided to put the other one back in again nothing.Put a jumper to the solenoid,starter turns ok,plugged in vcds and I'm getting no communication,my question is, is there a fuse or ing relay in the starting system or ecu relay,and nope I haven't connected up the wrong way.
  2. Re: mk 4 golf no crank.
    Sep 2008
    chester
    17 Post(s)
    Just an update if I run a jumper to the starter solenoid it will start and run so I'm wondering if the ignition switch is burn out,there's no voltage at the connector when turning the key to start.
  3. Re: mk 4 golf no crank.
    Sep 2008
    chester
    17 Post(s)
    Just an update,got the ignition switch out jumped the 50b ,it cranked so opened up the switch itself looked all ok nice bright contacts put it back together tried it again and hey presto it cranked on the key but no start,so scanned it and 1 fault for the 109 relay took that out opened it up all ok,back together plugged in,cleared the fault,car starts ok,all this just changing the battery,vw electrical gremlins,so my question is does the 109 relay power anything else besides the pump solenoid.just another aside the no communication with vcds was the usb connection on my laptop,another thing that got me head scratching.
  4. Re: mk 4 golf no crank.
    Apr 2016
    Ashburton
    Relay 109 supplies power to
    - Glow plug relay
    - Fuse 32
    ECM
    Fuel quantity adjuster
    - Fuse 34
    Cold start injector
    Waste gate bypass regulator valve (N75)
    Change over valve (N239)
    EGR vacuum regulator valve (N18)
    Mass air flow sensor (G70)
    - Fuse 43
    Clutch vacuum vent valve (if equipped)
    Brake vacuum vent valve
    Relays for preheating coolant (if equipped)
    Crankcase ventilation heating element
    The ECM supplies power (and sometime ground as well) for:
    Fuel cutoff valve
    Cruise control switch
    Manifold (intake) air pressure/Intake air temperature sensor
    Needle lift sensor
    Engine speed sensor
    Engine coolant sensor
    Closed throttle position switch (part of "go" pedal)
    Kickdown switch (part of "go" pedal)
    Throttle position switch (part of "go" pedal)
    Fuel temperature sensor
    Modulating piston displacement sensor
    The ECM also communicates to the instrument cluster electronics and transmission control module (on automatics).
    As a result of this, you can see why if the relay starts to cause power to flicker, or voltage drops, for all of these components, the results can be "unpredicatable" and none of them desireable.
  5. Re: mk 4 golf no crank.
    Sep 2008
    chester
    17 Post(s)
    Thanks for that turboextreme,as I stated above I traced it to the ignition switch giving no power to the solenoid,while I was in there I pulled the 109 out and back in and I think putting it back in it wasn't making a good contact,which threw me for a bit.
  1. Golf GT TDI 2.0 Crank, no start issue
    By jamesh89 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-03-2021, 10:34 PM
  2. Please Help MK4 GOLF Cambelt, crank pully removal
    By mike1983 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-09-2014, 03:57 PM
  3. crank sensor 54 plate golf
    By t4driver in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2009, 03:51 PM
  4. Question Golf Mk3 Crank Possition Sensor Golf Mk 3
    By mustanguy600 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-05-2008, 10:35 PM
  5. Crank Pulley Bolts on Golf Mk2 1.6d
    By wilharper2000 in forum Golf MK2 - 1984 - 1992
    Last Post: 31-08-2007, 04:34 PM
