Thread: Vibration at speed
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Vibration at speed
    Sep 2008
    6 Post(s)
    What's the mileage on this car? Vibration at speed is not a characteristic of any Quattro model. Stop using this garage - they obviously don't know what they're talking about.
    Rule out the straight forward things first. It's possible to have a flat spot on a tyre causing vibration if it's been damaged. Been there before.
    Regards brakes, then warped or pad transfer symptoms are easy to identify. Car needs to be up at about 70mph, brake rapidly. Any pulsating through the brake pedal could be siezed brake sliders or sticky piston. You can also drive car from cold and coast to a stop (no braking) after a few miles. Touch discs to confirm they're cold.
    Get a visual inspection of engine mounts. Unusual for them to fail.
    Any vibration through the gears? Don't want to suggest DMF or clutch release bearing, but some reports on B8.5 with 2.0 diesels failing prematurely, so would appear as a shudder in first gear.
    Keep us posted.
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  2. Re: Vibration at speed
    Mar 2016
    Wokingham UK
    Quote Originally Posted by spartacus 68 View Post
    Keep us posted.
    26K miles. Coming up to 4 years old. I bought at 24K. Had it for 5 or 6 weeks. New tyres. and that's probably why had the vibration initially. Since they carried out Road Force Balance it's been much better but likely to have now exposed underlying issue. I have tried changing down and up gears in manual mode, used sport etc. This doesn't have any affect. I will try the brake test and let you know. I don't recall any happening when braking at speed but want to try the coasting and feeling that you suggested. The vibration isn't there all the time and therefore I wonder if it's brake related.
  3. Re: Vibration at speed
    Jun 2017
    LB
    Quote Originally Posted by ib1703 View Post
    Do you do anything to encourage the clunk or does it just happen?
    In my case it just happens by itself at the slow speed mostly when I accelerate. It sometimes sound like the heatshield rattle.
    Sent from my SM-G928F using Tapatalk
  4. Re: Vibration at speed
    Sep 2017
    1. Go to local tire shop have them check for bent rim and speed balance each rim. 2. Best tires on any VW are PureContact DWS Continentals then ExtreamContact DWS both no road noise and will not disappoint you in snow or rain. And yes tires and rim are not the dealers strong points
  1. Question Vibration at speed
    By andyjgw in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-08-2014, 05:20 PM
  2. Vibration at speed
    By iwaters in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2011, 09:18 PM
  3. Vibration at speed
    By Paul Goodyear in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-12-2010, 11:48 AM
  4. Question Low speed DSG Vibration... Normal?
    By Mackey444 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-10-2010, 01:41 PM
  5. Mk4 1.6 vibration at speed
    By Mick100 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-01-2008, 09:43 PM
