Thread: Diagnosing a tick tick noise in the proximity of the PAS pump on a 2007 2.0 TDI (BRE) engine
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Diagnosing a tick tick noise in the proximity of the PAS pump on a 2007 2.0 TDI (BRE) engine
    #11
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Thanks for clearing that up, i didn't know they had the constant drive compressors fitted back in 2007. I've more recently had to look at my FIL's 2013 2 litre tdi yeti with a ticking noise, that was also from the ac compressor, which as far as i could see with a mirror (tight down there!) seemed to have three radially spaced drive plates riveted onto the pulley, the rivets wereloose and a fair bit red rust dust around the pulley so looked like it had been worn for some time. Presumabely this is also a constant drive modulating compressor. He got that changed by skoda under warranty so i never got to see the compressor removed.
    These engines use a different design of AC compressor to the longitudinal 3B with a constant drive modulated delivery system which places a variable load on the drive system without the in/out thump of a magnetic clutch compressor, so it goes quiet with the AC off?
  2. Re: Diagnosing a tick tick noise in the proximity of the PAS pump on a 2007 2.0 TDI (BRE) engine
    #12
    Apr 2009
    Replacing the Air conditioning pump solved the problem and the engine all sounds normal again. There was a small amount of play in the pulley and a definite grinding noise with the old part which the garage certainly had not seen before. Sadly only solved by replacing the whole air conditioning pump so not cheap but worth it to get rid of the noise.
  1. engine tick
    By kawaman in forum Golf MK5 - 2004 - 2009
    Last Post: 15-11-2010, 05:52 PM
  2. Vibs noise on tick over
    By engineer in forum Beetle 2000-
    Last Post: 15-06-2009, 09:32 PM
  3. Please Help A “tick tick” sound through the cubbyhole
    By maku in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-12-2008, 09:28 PM
  4. Evap Valve .... Tick...Tick....Tick
    By J..M in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2008, 05:20 PM
  5. Indicator 'tick tick' noise
    By avaghela in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-07-2007, 10:21 PM
