Thread: A4 2012 2.0 TDI Serpentine Belt Routing
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    Sep 2008
    chester
    17 Post(s)
    Is it the car symbol with a key inside,or what? describe,does sound like your immobiliser kicking in.
  2. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    Aug 2017
    Dawlish
    HI, thanks for replying.
    It's not the car symbol, it's the amber glow plug light that flashes & then a constant warning tone sounds. The engine turns over, then cuts out immediately after 1 second so I'm assuming it's something serious or maybe a sensor has been sheered off when the previous belt disintegrated.
    I think I need a VAGCOM specialist to come & plug into the car unless there's some obvious things to try.
    Thank you for helping by the way, really appreciate it.
  3. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    Sep 2008
    chester
    17 Post(s)
    Yes you'll need to get it scanned,otherwise its just guesswork.
  4. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    Aug 2017
    Dawlish
    Good day all
    The story so far! Have managed to find a local mechanic who is an absolute star. He came round, diagnosed & fixed the disabling of the engine & managed to get the car to move as far as his workshop, whereupon the replacement belt snapped again! It turns out the air con compressor is knackered so that needs replacing & the previous belt snap had knocked out the Cam Shaft sensor, so that needs replacing too. Not too bad on the whole so far, although he has found fragments of the previous two belts around the engine casing so I'm hoping it hasn't affected the cam shaft alignment & timing belt - fingers crossed.
    Thankfully he can fix everything, which is more than the Audi specialists did when I took it to them (that's another story). Lesson learnt here - use your air con & get it serviced regularly, otherwise the compressor siezes up & the impact can be disastrous (as I've found out). Oh, I've also purchased Ross-Tech's HEX-V2 kit so will be plugging that in when the car comes back & getting used to reading the thing as much as I can.
    Thanks to you all for your posts & help - it's very much appreciated.
    Happy driving
    Ian (aka Windsor)
  5. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    Aug 2017
    Dawlish
    Afternoon all
    Long time, no speak but still here & the ongoing saga with my delightful A4 continues. It's coming back from my mechanic today, having confirmed that the last aux belt break has in fact knackered the timing of the cambelt & as a result, the engine is totally knackered. I'm now stuck with a nice A4 that won't work & needs a new engine, however I'm really thinking of now getting rid of it. Need some further advice please:
    1. Any ideas on where to get a new engine would be appreciated? I've been quoted various 4 figure sums so far & am thinking that it's probably best to just write the car off & get a smaller more economical one, now that I'm not doing the miles. however if anyone knows of somewhere I can get a decent replacement engine, I'd be only too happy to know.
    2. Failing that, any ideas on where I can go to scrap the car? I've seen various websites offering great prices & car collection but I've no experience of them, so any advice would be welcomed.
    Many thanks
    Ian
  6. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    May 2011
    london
    Sell it on ebay as spares and repair. You should get more than scrap.
    Sent from my HTC 10 using Tapatalk
  7. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    #17
    Ardfern
    8 Post(s)
    I agree that selling on ebay is likely to yield the best price.
    Sorry to hear of your misfortune. Thanks for sharing the experience which stands as a warning to us all.
    You could of course offer in the marketplace section on this forum first.
    Good luck.
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  8. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    #18
    Sep 2008
    chester
    17 Post(s)
    You might be lucky and it maybe just some bent valves,or worse bent conrod might be worth taking the head off to see,your problem is if you have to pay for the labour the cost stacks up so selling o on ebay for spares may be your best option.just a aside is the engine running at all?
  9. Re: A4 2012 2.0 TDI Serpentine Belt Routing
    #19
    Aug 2017
    Dawlish
    Thanks for the info, most helpful. Sadly the engine won't start at all now & as you say, it's paying for someone's time to do all this that would just stack up & there may be no chance of getting it fixed anyway. My mechanic has a mate who used to work for Audi so he's trying to see if we can source a replacement engine that we can fit, though it's likely it will need to go back to Audi for "reprogramming" into the car.
    Just waiting to hear back now. I'm hoping we can get it running again so that I can at least either use it for a while or sell it for something cheaper to run, now that I'm not doing the miles any more.
    Thanks again for all your help over the past few months, really appreciate it.
    Ian
  1. Squeaky Aux / serpentine belt caused by belt or pully? Video included.
    By mikeote in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-07-2016, 09:13 PM
  2. Power Steering belt routing
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 04-06-2013, 12:00 AM
  3. Please Help does anyone have a diagram of the serpentine belt routing for a 2.0 tdi 140?
    By ThEgOg in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-03-2012, 10:56 PM
  4. rear middle seat belt routing
    By warp_speed in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-09-2011, 01:00 PM
  5. vibrating noise & belt slip on full lock- serpentine belt tensioner?
    By VtecJunkie in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-12-2009, 04:39 PM
