Thread: Swirl flap actuator
  1. Swirl flap actuator
    Aug 2017
    Ellesmere Port
    Hey,
    Quick question. This has a vacuum pipe connected to it so I pulled it off and there is nothing there. When is there an actual suction to operate the swirl flaps?
    Thank you in advanced
  2. Re: Swirl flap actuator
    Oct 2010
    Here And There
    You will have some sort of actuator valve that operates the vacuum. E.g. n75
    Sent from my SM-G925F using Tapatalk
  3. Re: Swirl flap actuator
    Aug 2017
    Ellesmere Port
    Quote Originally Posted by A4 Lad View Post
    Hey A4-lad,
    With it being a vacuum hose would I not feel some sort of suction on the pipe?
  4. Re: Swirl flap actuator
    Oct 2010
    Here And There
    Do you have any sort of diag reader ? You should be able to activate it through there
  5. Re: Swirl flap actuator
    Aug 2017
    Ellesmere Port
    I only have a cheap one so will have a word with a mate of mine.
    Thanks much appreciated
  1. Passat 2.0 Diesel inlet manifold leaking oil on swirl flap actuator.
    By Bert514 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-10-2016, 12:09 AM
  2. swirl flap kits..
    By swalker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-09-2016, 12:16 PM
  3. Swirl flap motor / actuator A6 2.7 tdi BPP
    By fmc51 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-07-2015, 03:10 PM
  4. 2.0 PD TDI - swirl flap removal... anyone done it?
    By tubdub in forum 2.0TDi - Engine
    Last Post: 17-01-2014, 01:07 AM
  5. Please Help 3.0 V6 TDi Swirl Flap Repair Kit
    By bigman1 in forum Touareg
    Last Post: 15-07-2013, 05:09 PM
