Thread: Misbehaving navigation
Results 1 to 9 of 9
  1. Misbehaving navigation
    Mar 2009
    North Yorkshire
    6 Post(s)
    Anyone had this or have any ideas about what might be happening?
    On several separate occasions my A7's navigation has placed the car about 250-300m from its actual location, which leaves it thinking I am driving 'off road' and causes it to constantly recalculate, really annoying and unhelpful.
    First time it only reverted back to an accurate location on the following day (despite turning everything on and off twice in an attempt to reset it). Today it sorted itself out while I was driving.
    On both occasions the speed camera display and active cruise have also stopped working...
    Any ideas what's going on, everything works fine for 95% of the time.
    Audi A7 TDI quattro, 272 ps Black Edition - Tornado Grey, black leather, 20" twin spoke titanium wheels, air suspension, ambient lighting, tech pack adv, parking pack adv, speed limit display, htd front & rear seats, adaptive cruise, memory seats & dimming door mirrors. Gone now: 1 x BMW, 3 x Audi, 1 x Mercedes, 2 x Saab, 1 x Volvo, 3 x Peugeot, 3 x VW, 2 x Citroen, 3 x Ford, 6 x Vauxhall, 2 x MG, 2 x Triumph, Honda CB750K7, Suzuki GT250A.
  2. Re: Misbehaving navigation
    May 2012
    Brighton
    Many years ago I had a garmin gps unit on a motorbike that did exactly the same thing
    Sitting on a dock awaiting a ferry and it thought I was 250 yards out in the Irish sea - constant recalculation as if thinks you are another road
    It was an internal error in the unit. Garmin swapped it for a new unit which solved the problem.
    I would imagine that is the likely solution for you as well
    2011 3.0 TDi Quattro 245 - Tech pack - rear camera - Stronic - heated steering wheel - side lane assist - ambient light - speedlimit display -advanced key
  3. Re: Misbehaving navigation
    Aug 2015
    West Mids
    7 Post(s)
    I had this exact issue, with examples of being a few hundred meters out, to the NAV thinking its back in Germany, It was an intermittent fault but when it went rogue it was at the most inconvenient time you could imagine!, luckily when I took the car to the dealer the nav was displaying the location two roads over, Audi identified the fault to the antenna and replaced it, this included the external fin which I thought they could salvage the original casing casing, unfortunately up close you can see mine is a replacement
    Audi A7 (2012), Black Edition 245 PS Tiptronic, Phantom Black
  4. Re: Misbehaving navigation
    Feb 2013
    Gloucester
    57 Post(s)
    Speed camera display? How do you get that?
    Sent from my iPhone using Tapatalk Pro
  5. Re: Misbehaving navigation
    Mar 2009
    North Yorkshire
    6 Post(s)
    Sorry, a misstype, should be speed limit display...
  6. Re: Misbehaving navigation
    Feb 2013
    Gloucester
    57 Post(s)
    Damn! Got excited then - although with a speed camera warning the car would beep from the second the engine is switched on to the second it goes off!
  7. Re: Misbehaving navigation
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Its the external roof antenna, common fault and easily replaceable. You dont need to have a replacement resprayed as the outer casing is removable. Alternatively you can use a cheap gps antenna from ebay and plug it into the back of the mmi unit.
  8. Re: Misbehaving navigation
    Mar 2009
    North Yorkshire
    6 Post(s)
    Happened again yesterday, it's a real nuisance when you're actually relying on the navigation
  9. Re: Misbehaving navigation
    Dec 2013
    Ireland
    Interesting. So you can bypass the roof fin and plug something into the mmi unit. What needs to be bought please, and where does one access the MMI unit? Much appreciated.
  1. Audi S4 B6 tip box misbehaving
    By a19tgg in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-11-2016, 10:24 AM
  2. Android Auto / Google Maps navigation vs Inbuilt Nav Pro navigation
    By MattB247 in forum Passat - B8 Forum - 2015 -
    Last Post: 25-08-2016, 03:57 PM
  3. Misbehaving/not starting
    By Milu- in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-03-2012, 09:10 PM
  4. Please Help newbie with a misbehaving a3
    By saffronbuns in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-10-2010, 02:53 PM
  5. water in the car now electrics misbehaving
    By speedy2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2009, 06:24 PM
