Thread: VCDS coding not accepted, no registered interface even though it is
  1. Question VCDS coding not accepted, no registered interface even though it is
    Aug 2017
    Paris
    Hello!
    I've been using this forum a lot to modify previousyly owned cars. Today I have an Audi A6 C7 which I have tried to use the long coder on without success. I tried to activate DRL option in MMI by activating the bit, but it didnt work becuase it says i dont have a licensed interface. However, I can without any problem uncheck a bit and it accepts it; it did so when a deactivated the tail lights for DRL. At the same time, I cant see what the different bits are. Any help how to fix this?
    At the moment however I have a license status that says activated and valid.
    Jep
  2. Re: VCDS coding not accepted, no registered interface even though it is
    Feb 2013
    Gloucester
    57 Post(s)
    Definitely on the latest software, and you have tested and saved the link with the car?
    Sent from my iPhone using Tapatalk Pro
  1. VCDS + HEX-NET Interface - West Sussex
    By andyhud007 in forum VCDS - Users Locations
    Last Post: 03-03-2022, 06:46 PM
  2. vcds lite registered help
    By joe67 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-08-2016, 11:10 AM
  3. VCDS HEX-USB+CAN Interface
    By stuart in forum Site Sponsors - Current Group Buys
    Last Post: 25-11-2014, 06:31 AM
  4. Passat B5.5 (2002) compatible with VCDS Lite registered?
    By VAGMAN2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-01-2012, 04:08 PM
  5. Confused!! Which VCDS interface??
    By lodgey47 in forum VCDS - General Questions
    Last Post: 21-01-2011, 12:55 PM
