Thread: VW Golf mk 6 1.6 electrical fault ??
  1. VW Golf mk 6 1.6 electrical fault ??
    Apr 2017
    GB
    I have noticed the last day or two when I open doors on car interior lights do not come on, what could this be ?
    Also factory fitted alarm sets when I press on key fob but when set off no alarm siren just flashing indicators.
    Any advice would be most welcome ?
    Carmine
    Sent from my P8 using Tapatalk
  2. Re: VW Golf mk 6 1.6 electrical fault ??
    1841 Post(s)
    A global scan of the cars system is required plus some studying of what are known as "measuring blocks" in the appropriate controllers, namely the central convenience system and the drivers door controller. As a guess I would say the drivers door lock unit is faulty.
  3. Re: VW Golf mk 6 1.6 electrical fault ??
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Crasher means global scan with VAG-COM\VCDS.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: VW Golf mk 6 1.6 electrical fault ??
    Apr 2017
    GB
    Sorry in English please ?? Lol
  5. Re: VW Golf mk 6 1.6 electrical fault ??
    Apr 2017
    GB
    Do you mean at any garage link it to machine ??
  6. Re: VW Golf mk 6 1.6 electrical fault ??
    1841 Post(s)
    It needs a fault code read of all the cars systems, print these out, clear all the codes and then run the car for a while then re-read, this way whatever comes back you know is real. The best system easily available is VCDS which almost all independent VAG specialists will have and also many all makes garages also have, generic scanner systems used by almost every garage in the country can tend to give very unreliable and misleading results, especially Snap Off systems.
  7. Re: VW Golf mk 6 1.6 electrical fault ??
    Apr 2017
    GB
    I haven't taken the car anywhere but noticed that above windscreen where you have interior lights when I open doors now interior light do come on and off after timer once doors are shut. I found hat if it didn't work just gently tapped unit where lights are and it works. Just have to see why alarm trumpet does not work
  1. mk4 golf gti electrical fault
    By marcus.tarpey@v in forum VCDS - General Questions
    Last Post: 16-09-2008, 01:55 PM
  2. Re: VW Golf 1.6se electrical fault
    By londonguy in forum Golf MK4 - 1999 - 2004
    Last Post: 21-04-2008, 08:07 PM
  3. Major Electrical Fault Golf MK4 2003
    By vanrudi in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2007, 02:11 PM
  4. golf gti mk3 electrical fault
    By s194smith in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2007, 10:11 PM
  5. 2002 Golf TDi electrical? fault
    By Trained Monkey in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-01-2007, 12:40 PM
