Thread: Flashing PRNDS lights on dash
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Flashing PRNDS lights on dash
    Sep 2017
    Port Coquitlam, BC, Canada
    It's been at least 8 years that I did one but it's at the back of the gearbox. I don't remember requiring VCDS or VAS to get going. The part came from the dealership and my shop replaced the old part.
  2. Re: Flashing PRNDS lights on dash
    1836 Post(s)
    Quote Originally Posted by Heilanpiper View Post
    It's definitely the Transmission Controller Range detection at fault as it cannot detect the Gear Position.
    Yes, the F125 switch, this is inside the box and part of the ECU unit with these boxes. The switch is magnetic and is often covered in metallic particles from normal transmission wear. Once I tried cleaning the particles off but after all that work and fluid I still had to pull it apart again and fit a new ECU. ALL this is conjecture though without a fault code report and I don't think this thread should go any further without one, it is into page 2 now and we have no code report which is silly.
  3. Re: Flashing PRNDS lights on dash
    Dec 2016
    Glasgow
    So I got the diagnostic done and have two faults:
    16891 - Idle Control System RPM: Higher than Expected.
    P0507 - 001 - Upper Limit Exceeded – Intermittent
    17090 - Transmission Range Sensor (F125): Implausible Signal
    P0706 - 000 - - - Intermittent
    The F125 Fault I was expecting as I have read about people getting this with the PRNDS flashing lights, however I was not expecting the idle control one.
    However I will get round to removing TCU on the rear of the gearbox and will re-solder the wire contacts to see if this does the trick.
  4. Re: Flashing PRNDS lights on dash
    1836 Post(s)
    What is the engine type code and the cars year?
  5. Re: Flashing PRNDS lights on dash
    Dec 2016
    Glasgow
    Its a 2005 year , I will check the engine code, but size is 1.8 T
  6. Re: Flashing PRNDS lights on dash
    1836 Post(s)
    I would expect the engine code is the crankcase ventilation system one way valve
    [IMG][/IMG]
  1. Few lights on the dash flashing
    By Dean_1987 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-12-2015, 12:48 PM
  2. Question Flashing Car Lights On Dash
    By motionpotion in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-07-2014, 06:52 PM
  3. Question Prnds flashing?
    By Shawrigg in forum Touran - Sharan - Caravelle
    Last Post: 13-04-2014, 09:44 AM
  4. Question PRNDS flashing
    By ChristopherF in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-02-2011, 10:50 AM
  5. Please Help PRNDS Flashing
    By GJC in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2010, 10:36 AM
