Thread: Audi A6 C6 4F 2007 SEDAN 2.0 TDI - Using coolant / leaking coolant = 1 Liter a week
  1. Audi A6 C6 4F 2007 SEDAN 2.0 TDI - Using coolant / leaking coolant = 1 Liter a week
    Aug 2017
    I don't know what to do, had the car in for pressure testing over some hours but they diden't find any leak, not even traces of leaks.
    But i need to fill 1 liter once a week with coolant / water.
    I googled little about this problem and found a post about cracked sylinder head? then water goes into head etc, i don't know if that problem is on mine tho, it goes well, starts well
    i read about white smoke, i took a video of my car, maybe you guys can see if this is normal smoke on a car that is not warm yet and the temperature outside is about 15 ish.
    Video of my care on idle:
    A6 c6 4f 2007 sedan 2.0 tdi idle - YouTube
    regards Stian
    -Car: Audi A6 C6 4F 2.0 TDI 2007 SEDAN Black
    -Stian
  2. Re: Audi A6 C6 4F 2007 SEDAN 2.0 TDI - Using coolant / leaking coolant = 1 Liter a week
    Jul 2013
    76 Post(s)
    Try replacing the coolant bottle cap.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Audi A6 C6 4F 2007 SEDAN 2.0 TDI - Using coolant / leaking coolant = 1 Liter a week
    Aug 2017
    I hear sound of little pressure letting out when i screw off the lid
    So it can't be the lid or could it anyway?
    If lid, how does 1 liter a week dissapear ?. steaming out of the lid?, then should'nt it be a trace after leakage?
    -Stian
    -Stian
  4. Re: Audi A6 C6 4F 2007 SEDAN 2.0 TDI - Using coolant / leaking coolant = 1 Liter a week
    Mar 2009
    Montenegro
    13 Post(s)
    According to my opinion, the coolant is intering into cylinder seen these steam coming out. It is not so cold to make the steam. Behind the head, the coolant can get into cylinders through EGR cooler and oil cooler as well.
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  5. Re: Audi A6 C6 4F 2007 SEDAN 2.0 TDI - Using coolant / leaking coolant = 1 Liter a week
    May 2008
    26 Post(s)
    How does the underside of the oil filler cap look? Nice clean normal oil, or thick like black mayonnaise? If the latter then your coolant could be leaking into the oil and you'll be in for a very expensive repair if you don't catch it in time.
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  6. Re: Audi A6 C6 4F 2007 SEDAN 2.0 TDI - Using coolant / leaking coolant = 1 Liter a week
    Aug 2017
    Ålesund Norway
    Exactly the same problem on my car. I had it to the audi garage and the result is the head gasket or a crack on the block engine.
    Sent from my iPhone using Tapatalk Pro
  7. Re: Audi A6 C6 4F 2007 SEDAN 2.0 TDI - Using coolant / leaking coolant = 1 Liter a week
    Aug 2017
    Ålesund Norway
    2008 Audi A6 2.0 TDI Head gasket problem - YouTube
  1. Coolant Issue audi A4 2.0TDI 2007 84000miles
    By Lane End in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-05-2017, 07:52 PM
  2. Leaking Coolant, HELP!!!
    By Bad Mav in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-10-2010, 10:31 PM
  3. Leaking coolant?!?
    By AudiTsport99 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-07-2010, 07:52 PM
  4. Please Help AUDI 2.0TDI.coolant dissapear,no marks of leaking...
    By atmos in forum Audi A3 - Archive Topics
    Last Post: 17-03-2009, 05:36 PM
  5. Leaking coolant!!
    By nakhonian in forum Vento - 1994 - 1998
    Last Post: 30-12-2007, 01:16 PM
