Thread: Help stuck cant remove driveshaft
  1. Help stuck cant remove driveshaft
    Oct 2016
    birminghan
    Hi guys im trying to remove driveshaft i have read you dont need to remove the arms but i cant get the shaft to come out it either hits on the transmision oil pipe at the tranny end and the axle dont fully come out the bearing end i have tryed wigling with no progress should i take off top control arms cheers
  2. Re: Help stuck cant remove driveshaft
    Oct 2016
    birminghan
    Hi finally removed the shaft is it suppose to.make a suction noise vid attached guys all help.appreciated Audi cvt b7 auto driveshaft noise - YouTube
  3. Re: Help stuck cant remove driveshaft
    Oct 2014
    London, UK
    9 Post(s)
    Quote Originally Posted by yaza01 View Post
    Yes, it has a sealed boot each end which stops all of the grease escaping from the joints. The bar is hollow and so is the outboard joint (you screw the hub bolt into it) so when the joint plunges it push air in/out of the driveshaft assembly. Air comes out of the boot hole and you get a suction sound.
    Make sure you thoroughly check the boots for any splits and if they are split you will need to replace the boot and refill with grease.
  1. Do I need to remove CD changer to remove the glove box? A4 Avant 2007
    By cornishpasty in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-02-2015, 10:06 PM
  2. How to remove a stuck pin in radio wiring loom?
    By labrajaws in forum In Car Entertainment
    Last Post: 03-09-2011, 04:28 PM
  3. Please Help Im desperate! I need to remove the exhaust from my 1.4 and It's stuck!!!
    By adezmk3 in forum Golf MK3 - 1993 - 1999
    Last Post: 12-04-2010, 10:03 PM
  4. Fuel gauge stuck and brake stuck !
    By Satch in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-01-2009, 03:40 PM
  5. Question how to remove remove aero windscreen wiper...
    By Hotrocks888 in forum Chat - Anything with wheels
    Last Post: 22-11-2008, 04:45 PM
