Thread: Clutch/brake fluid leak under battery - 04 1.9TDi
  1. Clutch/brake fluid leak under battery - 04 1.9TDi
    Aug 2017
    BRISTOL
    Hi, new to this forum and hoping someone can assist...
    I have spotted a fluid leak which appears to be coming from somewhere underneath the battery. There is a fine layer of fluid covering components directly underneath the battery box. Can somebody pinpoint the most likely cause?
    Thanks in advance for any help
    David
  2. Re: Clutch/brake fluid leak under battery - 04 1.9TDi
    1842 Post(s)
    Yours has the external slave cylinder so it could be the nipple or hose connection leaking or the feed hose/pipe assembly which pre mid 2005 was a known weakness on all PQ35 platform cars and has been revised at least four times, I get the current number as being 1K2 721 465 BJ which is £98.65 genuine and as far as I can tell is genuine only.
  3. Re: Clutch/brake fluid leak under battery - 04 1.9TDi
    Aug 2017
    BRISTOL
    Thanks for the info, much appreciated!
  1. Replies: 5
    Last Post: 08-04-2013, 09:23 PM
  2. Please Help Esp & occasional abs light & brake fluid leak
    By tigerminx1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-09-2011, 08:12 PM
  3. fluid leak from clutch bell housing
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2011, 02:14 PM
  4. Golf GTi 8v Brake Fluid leak
    By shepstermk3 in forum Golf MK3 - 1993 - 1999
    Last Post: 13-08-2008, 06:49 PM
  5. Brake fluid leak
    By grover in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-02-2008, 10:29 PM
