Thread: FUEL TEMPERATURE SENSOR LOOM..replace or bypass options
  1. Question FUEL TEMPERATURE SENSOR LOOM..replace or bypass options
    Aug 2017
    Bellshill
    Hi just bought a used 2005 1.9 diesel golf plus from auction and fixing it up. The car seems in great condition with minimal flaws so far fingers crossed but it does have broken wire loom. Its the wires going into the connector that attaches to temp sensor thats detached. Can these looms be purchased online and if so does anyone know part number ? Failing that is there an alternative fix for this to bypass it ? Fixing it is preferred option but open to a workaround if possible. Any help or advice much appreciated
  2. Re: FUEL TEMPERATURE SENSOR LOOM..replace or bypass options
    Dec 2014
    Bedford
    42 Post(s)
    Look at the connector you will find a part number. Order it from a dealer and ask for wires with same cross section diameter. One wire will come with a terminal on each end .
  3. Re: FUEL TEMPERATURE SENSOR LOOM..replace or bypass options
    1841 Post(s)
    The plug, should you break it, is 1J0 973 702 which is £3.79 and the single wire repair piece is 000 979 019 E and these are £5.04 each.
  1. Ahu Fuel Temperature Sensor
    By Grover2000 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-04-2013, 12:47 PM
  2. fuel temperature sensor
    By simj34 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-08-2012, 12:10 PM
  3. Please Help Fuel temperature sensor 140 PDi
    By Dozz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-07-2011, 10:23 PM
  4. Fuel Temperature sensor
    By gazwilson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-03-2010, 10:07 PM
  5. Fuel temperature sensor
    By rplc1976 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-03-2009, 02:29 PM
