Thread: 3.0 quattro starting issues
Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 163
  1. Re: 3.0 quattro starting issues
    #21
    Feb 2016
    Cheshire
    13 Post(s)
    I've ordered a sensor but here's the relays too
    Sent from my SM-G935F using Tapatalk
  2. Re: 3.0 quattro starting issues
    #22
    scotland
    39 Post(s)
    They look fine, pull the ECU connectors and check for any furring.
  3. Re: 3.0 quattro starting issues
    #23
    Feb 2016
    Cheshire
    13 Post(s)
    I can only get 1 side out but it looks fine
  4. Re: 3.0 quattro starting issues
    #24
    scotland
    39 Post(s)
    All good then
  5. Re: 3.0 quattro starting issues
    #25
    Feb 2016
    Cheshire
    13 Post(s)
    So in regards to the code reader picking up loads of faults could that just be down to a weak battery like the rac guy mentioned? Also the abs and esp light came on when he restarted it and didn't go out until he cleared the codes
  6. Re: 3.0 quattro starting issues
    #26
    scotland
    39 Post(s)
    Most systems will log erroneous codes due to a low battery. I wouldn't worry unless you see any of them come back.
  7. Re: 3.0 quattro starting issues
    #27
    Feb 2016
    Cheshire
    13 Post(s)
    Ok cheers. I'll report back when I've fitted this sensor and new battery
  8. Re: 3.0 quattro starting issues
    #28
    scotland
    39 Post(s)
    Keep my fingers crossed for you, good luck
  9. Re: 3.0 quattro starting issues
    #29
    Feb 2016
    Cheshire
    13 Post(s)
    So I put the new battery in and it fired up straight away. Tried again and it won't start, now the fan comes on and stays on until I remove the key and the oil pressure warning just came on too. And my code reader won't connect either
  10. Re: 3.0 quattro starting issues
    #30
    scotland
    39 Post(s)
    Try a hard reset, disconnect both battery leads then touch and hold the ends together for a count of ten, reconnect and see how it goes.
  1. 3TDi starting issues/ dying issues
    By 20vcqdriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2014, 10:01 AM
  2. Please Help Starting issues
    By jcr1977 in forum Leon
    Last Post: 19-07-2011, 10:32 PM
  3. 2.5 tdi quattro starting issues
    By Alex Welham in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-07-2011, 08:18 PM
  4. audi quattro 2.5 tdi a6 avant starting issues
    By rooos in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-05-2009, 09:54 PM
  5. Please Help 1.9 TDi (AFN) starting issues
    By Aeikostx in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-09-2008, 01:02 AM
