Thread: 3.0 quattro starting issues
Page 2 of 17 FirstFirst 123412 ... LastLast
Results 11 to 20 of 163
  1. Re: 3.0 quattro starting issues
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Yeah , plenum chamber is just the fancy name for the space for the skuttle well that you have water in, good luck and I hope your 3.0 cabby is not spoilt by an expensive ECU bill
  2. Re: 3.0 quattro starting issues
    Feb 2016
    Cheshire
    13 Post(s)
    Quote Originally Posted by fourringsrus View Post
    Aah got you. I'll check it out. Just been speaking to my mate and he knows a lad who had an A4 with the same water issue.
    I'm hoping it's not a problem with the ECU but I didn't realise how cheap you can pick them up for, but obviously the question is how much to be reprogrammed?
    Hopefully it is just the battery which is causing the issue though I will take the ecu out and have a good look round for water ingress.
    Interestingly the car started a few times in the drive but then refused to start a few times also?
    Sent from my SM-G935F using Tapatalk
  3. Re: 3.0 quattro starting issues
    scotland
    39 Post(s)
    Sounds like the crank angle sensor to me G28, watch the rev counter when starting if the needle doesn't move when you turn the key the ECU isn't getting a signal from it, cheap part to replace and a common failure.
  4. Re: 3.0 quattro starting issues
    Feb 2016
    Cheshire
    13 Post(s)
    Quote Originally Posted by calum View Post
    I've just had a read through some other posts regarding the sensor. It sounds like a possible cause in relation to the starting issue. I don't recall any stalling issues though. Roughly how much is one of these sensors?
  5. Re: 3.0 quattro starting issues
    scotland
    39 Post(s)
    Pattern one off EBay with two year warranty around £10, Audi probably nearer £50, EuroCarParts about £40.
  6. Re: 3.0 quattro starting issues
    Southern County Softy
    20 Post(s)
    There are relays under the ECU in the box.
    I've had water in the ECU box, I found relays under water when I removed the cover.
    2 relays had corroded and had to be replaced.
    A4 2.5 tdi QS (mapped)
  7. Re: 3.0 quattro starting issues
    #17
    Feb 2016
    Cheshire
    13 Post(s)
    Hopefully I'll be able to get into the box tonight and see what's going on. I'll get a new battery, and have a look at that sensor, do you have a link to it?
  8. Re: 3.0 quattro starting issues
    #18
    scotland
    39 Post(s)
    Here's a link for the part, CRANKSHAFT CRANK ANGLE POSITION SENSOR FOR AUDI SEAT SKODA VW CPS SHAFT
    Be careful removing the trim that sits below the wipers sometimes they are brittle, just take your time and work from one side to the other, it should come off in one piece. My car didn't stall with the crank angle sensor fault but sometimes it would feel as if the ignition was switched off for a split second.
    Here's a link on where it is and how to remove it. Crankshaft position sensor on a 05 Audi A4 3.0L V6 - YouTube
    1 1 0
  9. Re: 3.0 quattro starting issues
    #19
    Feb 2016
    Cheshire
    13 Post(s)
    So I've managed to get into the ecu housing and it looks as dry as a bone with no signs of water ingress...
  10. Re: 3.0 quattro starting issues
    #20
    scotland
    39 Post(s)
    Pull the relays see how they look. Get a crank angle sensor, it's cheap and the most likely suspect.
  1. 3TDi starting issues/ dying issues
    By 20vcqdriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2014, 10:01 AM
  2. Please Help Starting issues
    By jcr1977 in forum Leon
    Last Post: 19-07-2011, 10:32 PM
  3. 2.5 tdi quattro starting issues
    By Alex Welham in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-07-2011, 08:18 PM
  4. audi quattro 2.5 tdi a6 avant starting issues
    By rooos in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-05-2009, 09:54 PM
  5. Please Help 1.9 TDi (AFN) starting issues
    By Aeikostx in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-09-2008, 01:02 AM
