Thread: golf cabriolet staring/cutting out issues
  1. golf cabriolet staring/cutting out issues
    Sep 2010
    London
    Hello All
    Ive just picked up a 1999 MK4 Golf Cabriolet
    the car was cheap as it had issues cutting out and or starting
    I've sent it to a mate of mine who runs a VAG garage in Swanley in Kent (he is excellent by the way) pm me for his details if your in the area and or need some work doing
    he replaced some pipes/hoses and gave the car a good looking over, suggested the exhaust needs replacing or at least will in the near future
    however it would seem that the immobiliser is to blame for the starting or cutting out issues,
    he has suggested putting a new ignition barrel in but the cost seems huge compared to the value of the car
    has anyone had this problem and or does anyone know of anyone who could look into faults on the immobiliser
    thanks in advance
    regards
  2. Re: golf cabriolet staring/cutting out issues
    Jul 2007
    glasgow
    35 Post(s)
    has he scanned the car ??
  3. Re: golf cabriolet staring/cutting out issues
    Dec 2010
    Worcs, UK
    I am heading into London for work next week.
    The mk4 convertible is actually a mk3 technically (all the underpinnings are).
    The coil for immobiliser should be relatively cheap. Can scan car for you and find out what the issue is. Reader coil is relatively easy to replace, if anything a bit awkward.
    Can also reprogram keys to immo - if you have all to hand. Takes about 2 minutes and would show if there is an issue with transponder itself.
  4. Re: golf cabriolet staring/cutting out issues
    Sep 2010
    London
    Quote Originally Posted by itavaltalainen View Post
    This sounds perfect. The car was scanned by the mechanic who said he was going to get the codes over to me. Oh well.
    He did say that they all pointed to the immobiliser
    Only have 1 key. If I buy another off ebay can you program that also.
    How much would you charge.
    Thanks.
    Sent from my SM-N910F using Tapatalk
  5. Re: golf cabriolet staring/cutting out issues
    Sep 2010
    London
    Quote Originally Posted by niall campbell View Post
    Said he did and that they pointed to the immobiliser.
    Also said he would get the codes over. Guess he has been busy
  6. Re: golf cabriolet staring/cutting out issues
    Dec 2010
    Worcs, UK
    Send me a personal message with your details (phone number).
    If you get a key off ebay and get the blade cut and it has a transponder in it I can program it. You can also get one cut at locksmith, they are only about 15 quid cut with transponder that can be coded to car (you could even use transponder from breakers).
    New key should have an ID33 transponder in it, e.g. VW T4 Golf Passat Polo Sharan Vento Seat Marabella Toledo Schlüssel +Transponder | eBay
    Will need 1 working key that is authorised on immobiliser (i.e. your current key).
    Just for key programming etc I don't charge a lot, depends on how far I have to travel. I'll be fairly central in London for work (just inside CC), which end of town are you?
  7. Re: golf cabriolet staring/cutting out issues
    Sep 2010
    London
    Hi. Here is the key
  1. Question Golf 1.4S Cold Staring Problem
    By VWWindy in forum Golf MK6 - 2009 - 2013
    Last Post: 22-04-2016, 11:55 AM
  2. golf cabriolet mk4 steering wheel issues, please help
    By hotrod_boogie in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2011, 03:42 PM
  3. 2001 Golf Cabriolet 2.0 cutting out at low speed
    By fazersix in forum Golf MK4 - 1999 - 2004
    Last Post: 06-05-2011, 02:31 PM
  4. 1.8 golf cabriolet engine cutting out
    By hedgie in forum Golf MK3 - 1993 - 1999
    Last Post: 11-11-2008, 10:48 PM
  5. Cutting out problems with 1996 Golf 2.0 Cabriolet
    By John Brogan in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 05:05 PM
