Thread: Air con 2yr service
Results 1 to 8 of 8
  1. Air con 2yr service
    Mar 2016
    Banbury, UK
    I suspect everyone receives the main dealer email/phone call invitation to get the air conditioning system serviced after 2 years?
    Anyone know if it really makes any difference? And does anyone know what they actually service/clean/refresh for £75?
    Thanks.
  2. Re: Air con 2yr service
    Mar 2014
    Edinburgh
    235 Post(s)
    I had mine done under warranty when it was 18 months old as it wasn't as cold as I expected. It made a huge difference and instantly gets cold now.
    Unless the £75 includes the air con bomb to get rid of bacteria and smells then it's a bit expensive. Kwik fit does the guarantee if it's not colder they don't charge you for £50. It's just a simple re gassing. Most independent will do it for around the same.
  3. Re: Air con 2yr service
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I declined to have it done on my wife's 2 year old UP! earlier this year, but I dare say if your air con compressor packs up ( as my FIL's 4 year old yeti did when the pulley drive plate rivets came out) then a full service history including this air con service might stand you in better stead for any out of warranty goodwill. Personally i didn't think it worthwhile or necessary on our car as it's done about 7k in 2 years and air con is very rarely used.
  4. Re: Air con 2yr service
    Stratford upon Avon UK
    36 Post(s)
    They change the pollen filter and (I believe) also do the sanitisation thing.
    Not sure it includes a re-charge... they offered me that at the last service and I declined but I did have it done alongside the MOT this year and it is quicker at dropping the internal temp.
    Bear in mind that an aircon re-charge SHOULD be a complete re-charge and not some cheap "top up". The systems are designed to run with a specific weight of gas in them so they should be emptied and then a full (weight) charge put back in...
    A6 allroad BiTdi (MY14, July 2013 - DAB & power tailgate). Glacier white, tech pack (HDD Nav, colour DIS, Parking Plus), sports seats, 4 zone climate, heated seats front and rear, ambient lighting, 75L fuel tank, adaptive Bi Xenon headlights
  5. Re: Air con 2yr service
    Apr 2009
    Surrey
    174 Post(s)
    Quote Originally Posted by Rob69 View Post
    Not using is actually worse as the seals can dry out leading to loss of fluid. Better to use it regularly
  6. Re: Air con 2yr service
    Nov 2010
    104 Post(s)
    good point - saying that, I rarely use it, she might use it all time for all I know !!
    Quote Originally Posted by johnsimcox View Post
  7. Re: Air con 2yr service
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by ukgroucho View Post
    They change the pollen filter and (I believe) also do the..
    Pollen filter gets changed in the inspection/major service normally regardless if you get the air con service.
  8. Re: Air con 2yr service
    Dec 2016
    Edinburgh, Scotland
    15 Post(s)
    I was advised to leave it if ok at 2y and get it done as a check up at the 3y service as most cars are still ok at that point. I had the BMW's done and it was noticeably cooler!
  1. Self service vs Main dealer service come sale time
    By Tinytimbo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-04-2016, 07:56 AM
  2. Replies: 2
    Last Post: 04-05-2012, 10:55 PM
  3. Service Indicator wont stop showing Service Now!
    By Glynn R in forum Golf MK5 - 2004 - 2009
    Last Post: 15-10-2011, 12:24 PM
  4. Replies: 3
    Last Post: 21-10-2008, 06:28 PM
  5. Does resetting service indicator set service regime to fixed?
    By golfgtdude in forum Golf MK5 - 2004 - 2009
    Last Post: 01-10-2007, 06:38 PM
