Thread: Differential
  1. Differential
    Mar 2016
    Wokingham UK
    I have an Audi A4 Quattro 2013 2L that appears to be having an issue with the differential and the differential is being replaced plus some kind of alignment(?) related to the differential. Should I be concerned that this has caused damage elsewhere?
  2. Re: Differential
    Dec 2016
    Coventry
    If it is the alignment that you are worried about:
    The (rear) differential is mounted in the rear sub-frame that also has the control arms for the suspension bolted to it. When it is removed from the car the chances of it going back on in exactly the same position are slim to none. The alignment is just to check the suspension is still aligned after the re-fit.
  1. B7 Rear Differential
    By Dalmation11 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-11-2016, 08:37 PM
  2. Sports Differential
    By Molokai in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-04-2013, 03:54 PM
  3. Gearbox Differential
    By jacko1337 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2013, 02:34 PM
  4. 1.8T quattro differential oil
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-08-2011, 08:14 PM
  5. Differential Problem?
    By Sparkie8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-08-2010, 01:23 PM
