Thread: Exhaust - bombing ?
  1. Exhaust - bombing ?
    May 2009
    Saddleworth, Yorkshire
    Hi, I have issue with my Audi A3 2.0 Tdi Quattro, 170bhp. It's a 56 plate with a gen 66,000 miles. The issue I have is a a droning / booming noise emminating from the rear. It starts under load at 2,200 rpm and goes quiet at 2,400 rpm. Having had the wheel bearings checked I think it's the rear silencer. Not wanting to spend too much on a guess, I've been looking on eBay for a used one but there's a lot to choose from, hence my question - which rear section do I need, I guess the Quattro one will be different from a fwd. many thanks for any advice. Ian
  2. Re: Exhaust - bombing ?
    Mar 2017
    Coventry
    Hiya,
    Been reading these threads with interest looking for similar symptoms and what you guys have done to rectify the problems.
    Have been suffering from similar issue's with my 09 A4 s-line 103K miles. Droning sound from N/s rear indicative of wheel brg but investigation could not find play or any feel of worn brg! tyres are good so head scratching for fault, exhaust all good & mountings sound.
    Read a thread on here mentioning shocks! so as hard to tell if faulty i thought removal was only way to check for sure. hey presto N/s shock was absolutely useless little or no damping action. Purchased Sachs replacements from T.P.S. couple of hundred quid later what a difference in feel took all my time to compress the damper to allow installation.
    incidentally O/s was as good as new replacement.
    Just need to take car for a decent run to see if problem solved.
    Thanx to you guys for your shared experiences.
    Davmar
  1. Fix Audi code 01032 Exhaust Gas Recirculation Sensor B & 01027 Exhaust Gas Rec Circuit
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2017, 02:57 PM
  2. MPG dropping, smoke from exhaust, oil type liquid from exhaust too
    By UK_TIVO in forum Audi A3 - Archive Topics
    Last Post: 03-02-2009, 12:13 PM
  3. Polo sports exhaust / Exhaust Noise
    By peterb1 in forum Polo - Derby - Lupo - Fox
    Last Post: 08-09-2008, 10:40 AM
  4. To exhaust or not to exhaust, that is the question!
    By nickynibbles in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2007, 09:31 PM
