Thread: 02 TDI Foam Under Engine Cover Breaking Up - Replace or Remove?
  1. 02 TDI Foam Under Engine Cover Breaking Up - Replace or Remove?
    Sep 2008
    Changed the fuel filter this morning, there is an inverted 'u' shape piece of foam under the engine cover which has gone brittle and making a lot of mess. I guess its there for sound deadening?
    Quick question is it OK to remove or is a replacement available? can't seem to source one.
    Thanks!
    K
  2. Re: 02 TDI Foam Under Engine Cover Breaking Up - Replace or Remove?
    May 2012
    Everywhere
    308 Post(s)
    Remove and use three pieces of pipe lagging .
  3. Re: 02 TDI Foam Under Engine Cover Breaking Up - Replace or Remove?
    Sep 2008
    Quote Originally Posted by Gazwould View Post
    Excellent idea have some in the garage - Thanks, assuming its heatproof enough
  1. Question TDI Engine cover - how to remove?
    By gkmotorsport in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-02-2016, 06:58 PM
  2. Question Foam insulation collar - engine cover to rocker cover
    By Jeffmorgan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-01-2016, 01:33 PM
  3. Question Engine Cover Rubber Mount - how do I replace this?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2014, 09:39 PM
  4. Wanted Engine splash cover to cover the bottom engine bay and belts
    By vasi1982 in forum Golf MK3 - 1993 - 1999
    Last Post: 30-11-2011, 04:25 PM
  5. Remove the top black cover on the engine bay
    By nash232 in forum Ibiza - Cordoba
    Last Post: 04-04-2010, 02:10 PM
