Thread: Water damage ecu
  1. Water damage ecu
    Aug 2009
    liverpool
    During heavy rain my car cut out when I stopped at the light and the engine management light came on. After z few days it went off.
    After looking on google I found the ecu is right where water drains from the wind screen so water dripping in has damaged it. Is there anyway to stop this as it seems a very dodgy placentre to put a ecu. Thanks for help.
  2. Re: Water damage ecu
    1840 Post(s)
    Do you know the ECU is water damaged or are you assuming it is? Cutting out in heavy rain is often water getting into the intake system and confusing the Air Mass Meter.
  3. Re: Water damage ecu
    Aug 2009
    liverpool
    No Ive just googled with the ecu being in the position it is that's why I thought water damage as its a common fault.
    It cut out instead of stop/start
    I'll check the air intake tommorw or is it a normal thing and nothing to worry about
  4. Re: Water damage ecu
    1840 Post(s)
    I have never seen water damage to a type 36 engine ECU or even to the earlier type 3C. Before you do anything you need to have a code read carried out to see if anything is stored in the engine ECU memory.
  5. Re: Water damage ecu
    Aug 2009
    liverpool
    Thanks alot for help and advice I'll get code read and go from there.
  1. Replies: 1
    Last Post: 18-11-2011, 08:13 PM
  2. Help- need to replace ccu after water damage and code in replacment unit
    By GeeCee in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2011, 05:14 PM
  3. Water Leak - Permdnant damage?
    By r0bly0ns in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-09-2011, 02:13 PM
  4. water damage
    By ronnie.lynch@ho in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-08-2008, 09:06 PM
  5. water damage?
    By tony2311 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-10-2007, 12:11 AM
