Thread: Golf mk4 fault code
  1. Golf mk4 fault code
    Aug 2017
    melksham GB
    Hi everyone I have a 2002 golf 2.0 8v azj engine and have a fault code po113 air temp sensor circuit high, ive changed maf sensor not the problem also checked all wires to ecu and no open ones at all getting all correct voltage to and from mas sensor, car smells rich and idle isnt brilliant, if anyone has any other ideas as whats causing it that would be great as im puzzled
    Sent from my HUAWEI LYO-L01 using Tapatalk
  2. Re: Golf mk4 fault code
    10 Post(s)
    183 Post(s)
    You need to see what the actual value is in measuring blocks, does the code clear and then come straight back or does it take a while?
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  3. Re: Golf mk4 fault code
    Aug 2017
    melksham GB
    When I clear the code I drive a mile or so then switch engine off then when i start it up about 5 seconds later lights back on
  4. Re: Golf mk4 fault code
    10 Post(s)
    183 Post(s)
    Does your code reader show measuring blocks?
  5. Re: Golf mk4 fault code
    Aug 2017
    melksham GB
    No I dont think so I used an obd plug which works with phone, was the same fault code at the garage I went to, how do I test measuring blocks will look into it
  6. Re: Golf mk4 fault code
    10 Post(s)
    183 Post(s)
    You need a diagnostic system system that will show the data.
    1 1 0
  1. Question golf mk4 fault code helps
    By sps in forum Golf MK4 - 1999 - 2004
    Last Post: 23-08-2014, 11:11 PM
  2. help with fault code 00537 on mk3 golf
    By jay9866 in forum Golf MK3 - 1993 - 1999
    Last Post: 21-07-2012, 07:25 PM
  3. Question Fault code 05465 on Golf
    By trynfixit in forum Golf MK5 - 2004 - 2009
    Last Post: 07-03-2010, 09:01 PM
  4. VW Golf GTI MK4 Fault Code
    By Rossco4806 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 25-09-2009, 08:44 PM
  5. Mk3 GTI Golf ABS VAG.Com Fault Code
    By dravidham in forum Golf MK3 - 1993 - 1999
    Last Post: 01-01-2008, 11:29 PM
