Thread: ESP Light
  1. ESP Light
    May 2014
    bradford, west yorkshire
    can anyone help. my esp light keeps flickering on and off every so often and it causes the car to misfire, if i switch the esp off the car runs fine. as anyone had this problem or know how to fix it
    i have scanned it with vcds but there are no faults
  2. Re: ESP Light
    Dec 2013
    Skegness, UK
    Is vcds lite or full registered version? Lite version can't access every module to pull up stored DTCs
    ESP is linked to ABS. You can go into the ABS controller and check measuring blocks and take note of the values.
    One thing to note as well. They are quite dependent on specific voltages. Check your battery using a multimeter. Failing battery can cause a hell of a lot of problems just like the one you mentioned.
  3. Re: ESP Light
    Jun 2016
    Glasgow
    Yep, get ABS module scanned. Monitor live data on wheel speeds during road test (2nd operator required).
    Sent from my iPad using Tapatalk Pro
  4. Re: ESP Light
    May 2014
    i have scanned it again and its now come up with front right speed sensor, i take it thats my problem
  5. Re: ESP Light
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I've had that fault on my passat where one of the wheel sensors would come in and out of fault, the sensor tip was dirty, wiped clean and been ok for the last two years, could also be a poor connection at the plug as well.
  6. Re: ESP Light
    Dec 2013
    Skegness, UK
    Absolutely, clean contacts and make sure it's pushed in correctly.
    If fault persists, replace the sensor. Get part number, might be cheaper from dealers than eBay.
  7. Re: ESP Light
    May 2014
    could this also cause my speedo to jump slightly, say when im doing 60 it will bounce between 60 and 63 it doesnt climb smoothly
  8. Re: ESP Light
    Dec 2013
    Skegness, UK
    Certainly sounds plausible. If the speed sensor isn't making a good connection either by being loose or dirty it can give a faulty reading. Whip it off and clean the connector /sensor with isopropyl alcohol. When it's fully dry reconnect firmly and see how it goes from there.
    Keep me updated
  1. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2020, 07:34 PM
  2. Replies: 10
    Last Post: 02-01-2015, 05:08 PM
  3. should i buy? abs light, esp light and handbrake light flashing
    By craigq in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2011, 03:36 PM
  4. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  5. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
