Thread: A3 8p quattro timing adjustment
  1. A3 8p quattro timing adjustment
    Jul 2010
    Bangor, NI
    I was hoping that someone would be able to give me a quick walk through of how to adjust the timing on my 2007 audio A3 quarto.
    After a quick scan done by a friend with vagcom, I got the attached results.
    From what I have read, the Torsion Value should be a lot closer to 0, whereas mine is 3.72.
    I know that an adjustment needs done in the engine, but would like a bit of guidance if possible.
    Sent from my SM-T800 using Tapatalk
  2. Re: A3 8p quattro timing adjustment
    1837 Post(s)
    Lock the crank with the locking plate and then try and fit the cam pulley pins, adjust the pulleys after slackening the 13mm bolts using an18mm spanner on the centre bolt to tweak the cam hub without moving the belt.
  3. Re: A3 8p quattro timing adjustment
    Jul 2010
    Bangor, NI
    Thanks for the reply.
    Which cam hub is the one needing adjusted? Front or rear?
  4. Re: A3 8p quattro timing adjustment
    1837 Post(s)
    Technically speaking, both. The G40 sensor is on the inlet cam and you could tweak that to shut the warning up but if the exhaust cam is out, there is no point leaving it like that.
  1. A4 2.5tdi AKE quattro start injection quantity adjustment
    By Vellu in forum VCDS - Help Requests
    Last Post: 05-09-2013, 10:05 PM
  2. Replies: 0
    Last Post: 28-03-2013, 10:47 AM
  3. 2.5tdi timing adjustment
    By steve02 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-12-2012, 11:55 AM
  4. Question A3 1.8T Quattro Turbo Boost adjustment
    By Jungle in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-07-2010, 06:50 PM
  5. Please Help 17939 - P1531 - Camshshaft Timing Adjustment: Open Circuit
    By skipi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-06-2010, 11:01 PM
