Thread: Golf MK6 ANNOYING CODES P0113 P0238
  1. Golf MK6 ANNOYING CODES P0113 P0238
    Aug 2017
    uk
    Hi ive been having issues with these codes, There has been a loss of power which has caused a build up of soot in the DPF (but if i get a solution to this that should go) So i have read the codes with VCDS and this is what has come up
    Address 01: Engine Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 B HW: 03L 906 023 A
    Component and/or Version: 1,6l R4 CR td H23 9971
    Software Coding: 00114034032500080000
    Work Shop Code: WSC 01357 011 00200
    ASAM Dataset: EV_ECM16TDI02103L906023B 003011 (VW36)
    ROD: EV_ECM16TDI02103L906023DB.rod
    VCID: 254197B1243095699C-8070
    3 Faults Found:
    7295 - Manifold Pressure / Boost Sensor (G31)
    P0238 00 [165] - Signal too High
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 138716 km
    Date: 2017.08.08
    Time: 19:45:19
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 80 °C
    Intake air temperature: -40 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.972 V
    Unlearning counter according OBD: 40
    Engine speed: 0 /min
    Accelerator position: normalized-Accelerator position: 0.00 %
    Charge air pressure specified value-MAP_SP_MMV: 200.00 hPa
    Charge air pressure: actual value-MAP_MMV: 200.00 hPa
    Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
    Charge Pressure Actuator: acknowledgment-ANG_BPA[0]: 7.758 %
    7308 - Intake Air Temp. Sensor (G42)
    P0113 00 [037] - Signal too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 138716 km
    Date: 2017.08.08
    Time: 19:45:19
    Outside air temperature-Ambient temperature: 15.75 °C
    Battery voltage: 12.0 V
    16856 - Diesel Particle Filter
    P2463 00 [165] - Excessive Soot Accumulation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 138716 km
    Date: 2017.08.08
    Time: 19:45:19
    Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 40.01 g
    Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 39.74 g
    Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 716 km
    Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 0.0000 s
    Particle filter: difference pressure-DIP_PF: 0.00 hPa
    Particle filter: offset for differential press.-DIP_PF_AD[0]: 0.00 hPa
    Service regeneration: Release conditions 3-FRF_STATE_RGN: 9
    It says intake air temperature -40 which leads me to believe that theres a wiring issue, the problem is i dont know where or how to find where it may be, can someone help me with wiring diagrams or solutions im just an amateur so any help would be appreciated!
  2. Re: Golf MK6 ANNOYING CODES P0113 P0238
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    VAG Error Code: 16622/15984/000568/4166/5169/7295
    EOBD II Error Code: P0238
    Fault Location:
    Manifold Pressure/Boost Sensor (G31) - Signal too High
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Wiring/Connector(s).
    Manifold Pressure/Boost Sensor (G31) faulty.
    Possible Solutions:
    Check/Replace all faulty Wiring/Connector(s).
    Read Measuring Value Blocks (MVB).
    Check Manifold Pressure/Boost Sensor (G31).
    Signal voltage > 4.88 V.
    VAG Error Code: 16497/000275/20572/5282/4187/7308
    EOBD II Error Code: P0113
    Fault Location:
    Intake Air Temperature Sensor 1 (G42) - Signal too High
    Possible Cause:
    Fuse(s).
    Wiring/Connector(s) from/to Intake Air Temperature Sensor (G42) faulty.
    Intake Air Temperature Sensor 1 (G42).
    Possible Solutions:
    Check/Replace Fuse(s).
    Check/Replace faulty Wiring/Connector(s).
    Intake Air Temperature Sensor (G42) < -46°C.
    Check/Replace Intake Air Temperature Sensor (G42).
    When is the code detected?:
    An excessively high voltage from the sensor is sent to Engine Control Module (ECM).
    Description:
    The Intake Air Temperature Sensor is built into mass air flow sensor or in some vehicles mounted to the air filter duct housing. The sensor detects intake air
    temperature and transmits a signal to the Engine Control Module (ECM). The temperature sensing unit uses a thermistor which is sensitive to the change in
    temperature. Electrical resistance of the thermistor decreases in response to the temperature rise. The Intake Air Temperature signal is used as an input for
    various systems in the vehicle.
    VAG Error Code: 18895/23902/16856/009315/7388
    EOBD II Error Code: P2463
    Fault Location:
    Diesel Particulate Filter (DPF) - Excessive Soot Accumulation
    Possible Cause:
    Diesel Particulate Filter "full".
    Possible Solutions:
    Check Diesel Particulate Filter.
    Perform Emergency
    Regeneration
    Special Notes:
    Check the repair manual for any Technical Product Information (TPI)/Technical Service Bulletins (TSBs) related to dealer level engine control module software updates and revised replacement parts.
    As taken from my new EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Golf MK6 ANNOYING CODES P0113 P0238
    May 2007
    17 Post(s)
    Quote Originally Posted by Golfmk6code View Post
    I can't help you with a wiring diagram but I can tell you what the problem is likely to be from the data in your VCDS scan. It looks like your boost pressure sensor earth/ground is open circuit (probably a broken wire). With no earth to the sensor, the signal voltage will be 5V (ie too high). The IAT sensor is usually built into the boost pressure sensor and shares the same earth. The sensor earth might also be shared with the DPF pressure sensor too which might explain the DPF code as well.
    If you have a voltmeter and a sewing needle or a pin you can use to back probe the sensor connector I can tell you how to test the circuit to confirm my suspicion....or show me up as an idiot (wouldn't be the first time )
    The only problem might be getting at the sensor...see below.
  4. Golf MK6 ANNOYING CODES P0113 P0238
    May 2018
    London
    Quote Originally Posted by Flash2 View Post
    Is there any way you could tell me the way to test the ground on this circuit? I know to an old post but I have the same symptoms.
    Update:
    https://www.vwaudiforum.co.uk/forum/s...e-right-part-)
  1. Replies: 12
    Last Post: 13-04-2017, 08:34 AM
  2. OBD CODE P0113 - Intake Air Temp circuit high input - A3 BKC 1.9TDi Sport
    By bennoA3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-06-2016, 03:36 PM
  3. Please Help Golf tdi annoying misfire help
    By Desh1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-07-2015, 02:51 AM
  4. Fault P0238, P1556, P1103, P1136, P0011
    By *1.8 T Quattro* in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2011, 06:35 PM
  5. golf mk4 annoying creak from front end
    By jamez_ktm in forum Golf MK4 - 1999 - 2004
    Last Post: 27-02-2008, 09:08 AM
