Thread: B9 VCDS Coding?
  1. B9 VCDS Coding?
    Apr 2014
    Tamworth, Staffs, UK
    10 Post(s)
    Anyone know of anything interesting yet?
    Would love to invert the stop/start button as per my A6 but coding isn't the same.
  2. Re: B9 VCDS Coding?
    Apr 2014
    10 Post(s)
    Found some coding here; the Stop/Start one appears to work on the B9.
    Elektronica & Diagnose: My Tweaks A4 (B9)
    HTH
  3. Re: B9 VCDS Coding?
    Oct 2017
    I got a few from here.
    Q7 (4M) Coding
    I have done these:
    Need sweep - Completely useless and cool as ****
    Default distance setting for Adaptive cruise control.
    Beep on lock (mine is set to 1 for unlock, 2 for lock and increased to 60ms)
    Turn the volume on the soundacktor to zero.. It doesn't sound like a real engine anyway, so I might as well enjoy the quiet
    Enable & Pair a Second Phone via Bluetooth simultaneously (I have no Audi phone box)
    Increase time required to open trunk lid with remote key (now set at 2 secs - this has stopped a few mistaken openings)
  4. Re: B9 VCDS Coding?
    Aug 2015
    Cambridgeshire
    Was the soundaktor changed in VCDS following:
    Select Control Module
    A9- Struct. Borne Sound
    Adaptation - 10
    Set Channel to Volume of structure-borne noise actuator
    Change Stored Value to 0.0 to disable
    Click "Do It"
    Click "Yes" on VCDS Adaptation Warning
  5. Re: B9 VCDS Coding?
    Aug 2015
    Cambridgeshire
    I cannot access A9 so I'm assuming the soundaktor isn't installed on my A5. Here's a list of changes I've made so far:
    Gauge Test/Needle Sweep
    [17 Instruments] > Coding-07 > Long Coding Helper > Byte 1 > Enable Bit 0
    DRL option in MIB:
    [09 Central Electrics] > Coding-07 > Long Coding Helper > Byte 2 > Enable Bit 1
    Acoustic Lock/unlock:
    [46-Central Module] > Coding-07 > Long Coding Helper > Byte 4 > Enable Bit 6
    [ 46-Central Module ] > Adaptation - 10 > ENG146368-ENG146488-central_locking_system-beep_at_opening > activate
    Configure these channels as desired:
    Lock sounds: ENG146372-ENG146515-horn_settings-number_of_acoustic_acknowlagement_signals_zv_close (default 1 beep)
    Unlock sounds: ENG146372-ENG146514-horn_settings-number_of_acoustic_acknowlagement_signals_zv_open (default 2 beeps)
    My car was already set with the corresponding number of hazard blinks to mack the sound, so I've left as default.
  6. Re: B9 VCDS Coding?
    Aug 2015
    Cambridgeshire
    Here are a couple of helpful resources:
    ***Official*** B9 A5/S5/RS5 OBDEleven Coding Thread (Updated 8/6/2018) - AudiWorld Forums
    Complete VCDS - Vagcom mod list | Audi A5 Forum & Audi S5 Forum
    Does anyone know how to do the following:
    1. disable the 'passenger air bag on' warning/chime that is displayed every time the car is started
    2. disable the 'engine running' warning/chime every time the drivers door is opened
  7. Re: B9 VCDS Coding?
    Aug 2015
    Cambridgeshire
    Here are a few more changes I've made to my B9
    Comfort Blinking:
    [46-Central Module] > [Adaptation-10] > Turn Signal Control > Freeway Flashing Cycles > Current Value: 3 > New Value: 5 (1-5 possible)
    Increase time required to open boot with remote:
    [46 - Central Convenience] > [Adaptation - 10] > IDE08400-Actuation time to open rear lid with remote control > Current Value: 800 (ms) > New Value: 2000 > Do it
    Windows Open/Close with Fob:
    [46-Cent. Conv] > [Coding] > [Long Coding Helper] > Allow Experimental Data > Byte 12 > Bit 0 = Comfort_operation > active
    Enable Rear DRLs:
    [09-Central Elec] > [Coding-07] > [Long Coding Helper] > Allow Experimental Data > Byte 2 > Bit 3 = sl_at_drl
    Flashing Tail Lights with Emergency Brake:
    [46-Central Conv] > [Coding-07] > [Long Coding Helper] > Allow Experimental Data > Byte 21 > Bit 0 = Emergency_brake_indication_active
    Hazards Flashing with Emergency Stop:
    [46-Central Conv] > [Coding-07] > [Long Coding Helper] > Allow Experimental Data > Byte 36 > Bit 1 = Emergency_stop_hazard_flashing_active
    Engine Running Warning Off:
    [17-Instruments] > [Adaptation-10] > IDE06588-Ignition active message: actuator > changed from 'Driver Door' to 'No Display' this only turns off the message with ignition no, not engine running
  1. Wanted Vcds coding
    By luck333 in forum VCDS - General Questions
    Last Post: 30-05-2015, 10:24 PM
  2. VCDS coding for LED taillight kit
    By gdallas in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-11-2014, 06:04 PM
  3. Vcds coding options
    By Simon@DTUK in forum Golf MK4 - 1999 - 2004
    Last Post: 08-10-2014, 12:52 AM
  4. Question Vcds coding
    By Solo12 in forum VCDS - Help Requests
    Last Post: 11-07-2014, 08:03 PM
  5. bluetooth coding vcds
    By billyw in forum VCDS - Help Requests
    Last Post: 29-01-2011, 03:19 PM
