Thread: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
  1. 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Feb 2015
    United Kingdom, Oxford
    Hi all,
    All help gratefully received.
    2008 Passat 2.0 140HP common rail diesel, I believe a CBA engine on about 130K miles.
    After an error indication the throttle body was stuck open i have fitted a new
    throttle body the car was OK for about 500 miles then showed the boost pressure fault below and went into limp mode. Switch off and back on again and all was OK for a while.
    A bit of internet research suggested this might be a vacuum leak so after tinkering some I replaced the gasket between the exhaust gas return pipe and the EGR as i re-used the old one to try and fix the error, but now it seems to run OK for a mile or so then shows the fault and goes into limp mode.
    Questions:
    Any ideas what could be causing the Boost pressure problem - could it be something to do with changing the throttle body or is that a coincidence?
    I saw a suggestion of taking the vacuum line off the actuator on the turbo to test the N75 valve but if anything the car runs worse like that - even more gutless.
    I notice i have an electronic vacuum actuator on the turbo - is there anyway to test these - do they fail often??
    Thanks in advance.
    Getting to the end of my tether with this one. Already had to cancel my holiday as the car isn't reliable
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 FN HW: 03L 907 309
    Component: R4 2,0L EDC G000SG 2643
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 84224 802 739910
    VCID: 76B6EFF824C052D7075-8022
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 210049 km
    Time Indication: 0
    Date: 2017.08.06
    Time: 15:40:28
    Freeze Frame:
    RPM: 2277 /min
    Speed: 98.0 km/h
    Absolute Pres.: 2346.0 mbar
    Absolute Pres.: 1224.0 mbar
    Temperature: 28.8°C
    Mass Air / Rev.: 545.0 mg/str
    Lambda: 12.6 %
    Readiness: 0 0 0 0 0
    Sunday,06,August,2017,17:08:54:30454
    VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
    Data version: 20170721 DS276.2
    Ross-Tech: Home
  2. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I have read here and elsewhere that the turbo VNT actuators on those engines are prone to fail, not had much to do with these engines personally, but you can check for split tubing etc and the actuator diaphragm with a hand operated vacuum pump or a bit tube and a good suck, AFAIK a new actuator needs to be set up with vcds. a bit more info at these links, sure you'll find more:
    Please Help Mk V Golf 2.0 GT TDi PO299 Turbo Charger Low Boost Fault Code
    16683/P0299/000665 - Ross-Tech Wiki
    Darkside Developments - VW 2.0 16v TDI Common Rail Vacuum Actuator for CBAA / CBAB
  3. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Feb 2015
    Thanks Rob. Just been playing with VCDS - i have bugger all boost pressure, logging required and actual. Required spikes from 1000 mbar to 2500 odd mbar, the actual stays around 900 and actually dips a little when the required spikes. Questions is why...
    I've had all the vac pipes off and all look in good condition, and sucking on one end to pull a vacuum while blocking the other, all seem good - not very scientific...the one way valve from the vac pump seems ok too...
    However if i suck on the pipe from the actuator though, its not open, but i can keep sucking which would imply its not sealed....and may be the cause...
    How hard are these to set up? i have VCDS but have no clue how to set them up...
    Might need to invest in a vacuum tester...
  4. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Nov 2010
    104 Post(s)
    If you're sucking on the actuator and can keep drawing air then that suggests the actuator diaphragm is leaking, link in my previous post had replacement actuator costs. I found the same symptoms on my EGR actuator when that diaphragm was split. Sorry I can't tell you how to set these up, as I mentioned - not much experience on these engines.
  5. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    1836 Post(s)
    Failed actuator, suck on this!
    need repair kit 03L198716A at £157.33, awkward to fit and MUST be accurately set up.
  6. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Feb 2015
    That was the pipe i was sucking on with not much resistance. Have ordered a vac tester from Amazon, will be here tomorrow, so can test it a bit more scientifically. I think i can just about see the actuator rod with a torch, and that didn't appear to move either.
    So if the actuator fails - i suppose the vanes will be open, hence no boost pressure?
    Paul
  7. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    1836 Post(s)
    You have wasted your money ordering a vac pump, if you can suck air through that port the valve is FUBAR and therefore minimum boost.
  8. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Feb 2015
    It was a vac tester I ordered, sure it will get used again. Will have to ring the main dealer in the morning and see about getting it booked in. Not a job I fancy doing myself. Mant thanks for all the advice. Will post again with the ouToome.
    Last edited by s1paulj; 10-08-2017 at 08:34 PM. Reason: Spell checker changed word
  9. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    1836 Post(s)
    An experienced VAG specialist would have the equipment and the experience. Oddly one of the most important tools is a curved 10-mm spanner.
  10. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Feb 2015
    Vac tester confirmed - absolutely no vac. Booked into main dealer next week. Will update when i know more.
  1. Replies: 6
    Last Post: 12-09-2019, 05:46 PM
  2. P0299 - 006 - Control Range Not Reached - Intermittent B6 Passat
    By silversimpson in forum VCDS - Help Requests
    Last Post: 25-07-2019, 08:37 AM
  3. Replies: 0
    Last Post: 27-05-2015, 04:21 PM
  4. P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
    By Benoticed in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-07-2013, 04:37 PM
  5. Please Help 000665 - Boost Pressure Regulation: Control Range Not Reached
    By SebRogers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2011, 11:01 AM
