Thread: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #21
    Feb 2015
    United Kingdom, Oxford
    Hoping the lack of rod movement is due to split diaphragm. ....
  2. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #22
    Feb 2015
    Question, if VW come back and say it needs a new turbo, is that a fairly straight forward job. As if they do, i'll get a turbo and fit it myself if there is no setting up to do....
  3. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #23
    Feb 2015
    Another question, I'm going to tell the dealer NOT to do the emission fix while they have the car. Want to make sure this problem is fixed before potentially introducing another can of worms... Presumably i can read the software version on VCDS to check the before and after version, but not sure how to do that - can someone advise please - if i do a auto fault search will it also list the SW version??
    Paul
  4. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #24
    1836 Post(s)
    Take it to a competent specialist, they will fix it with a new actuator and won't ruin the car with a stupid unnecessary software change.
  5. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #25
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    But surely VW won't say it needs a new turbo until they've had the car in, removed the suspect actuator and checked the vnt operation, and you've committed to paying for their time and diagnosis? would you then take the car away and fit the turbo yourself and still have to fit a new actuator and set it up. Everything discussed here so far points to split diaphragm only, you can check vane operation once the actuator is off, fit and set up a new actuator or take to decent specialist as Crasher suggests.
  6. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #26
    Feb 2015
    So does a new turbo not come with the actuator?
    Anyone recommend a VW specialist in the Oxford area?
  7. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #27
    Dec 2014
    Bedford
    42 Post(s)
    New turbo comes with an actuator. 9 times out of ten its just the actuator diaphragm split.
  8. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #28
    Feb 2015
    Thanks.
    Is there a way to read the sw Version to confirm they haven't done the upgrade despite being asked not to?
  9. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #29
    Feb 2015
    Car dropped off at the dealers, now we wait.
    Did an autoscan of the fault codes as i dropped it off, only code showing was the boost regulation...
  10. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #30
    Feb 2015
    Garage confirmed the diagnosis that the vacuum actuator on the turbo is FUBAR. £416 to fit and set up the new actuator.
    So all in all an expensive month!
    £225 for VCDS
    £199 for new throttle body to fix 008450 - Throttle Valve Actuator Module (J338): Motor Circuit Motor Circuit P2102 - 000 - Signal Low - Intermittent
    £103 for a new lambda sensro to fix
    008598 - Oxygen (Lambda) Sensor B1 S1 P2196 - 000 - Signal too High (Rich) - MIL ON
    £416 for a new turbo vacuum actuator to fix
    Still at least i've done most of the work myself so saved a shed load...
    They say it comes in 3's so hoping that's it for a while....
    Many thanks for all the advice and help.
    Brilliant forum.
    Regards
    Paul
  1. Replies: 6
    Last Post: 12-09-2019, 05:46 PM
  2. P0299 - 006 - Control Range Not Reached - Intermittent B6 Passat
    By silversimpson in forum VCDS - Help Requests
    Last Post: 25-07-2019, 08:37 AM
  3. Replies: 0
    Last Post: 27-05-2015, 04:21 PM
  4. P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
    By Benoticed in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-07-2013, 04:37 PM
  5. Please Help 000665 - Boost Pressure Regulation: Control Range Not Reached
    By SebRogers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2011, 11:01 AM
