Thread: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
Results 11 to 20 of 34
  1. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Have they given you a price for changing and setting up this actuator?
  2. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Feb 2015
    United Kingdom, Oxford
    Not yet, they wanted to make their own diagnosis.
  3. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Dec 2014
    Bedford
    42 Post(s)
    Done a fair few. Very common. You can buy the tools on ebay. £17 .. You a get a slotted 10mm socket 1/4 drive and a 10mm slotted spanner. Takes less than hour unless you get issue with the turbo feed pipe and union. I have set the actuator rod to exact same length as the old unit. Had no problem with this. You should be using diagnostic machines and measured values to set it up correctly though. Oddly enough though i fitted a complete turbocharger which was showing the 299 underboost a few days ago (actuator diaphragm was fine but the vanes were almost seized) to a 2014 model which does not come with any manual afjustments of the actuator rod.
  4. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Nov 2010
    104 Post(s)
    Are you saying the turbo has to come off to change the actuator then and set up the rod length on the workbench ?
  5. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Dec 2014
    Bedford
    42 Post(s)
    No. Its easy enough just fiddly.
  6. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    Dec 2014
    Bedford
    42 Post(s)
    This is what i use
  7. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #17
    Nov 2010
    104 Post(s)
    Thanks for info - got a feeling I'll end up having to do this job on FIL's 2.0L Yeti at some point in the future, I've only had to poke around his engine a bit to diagnose a rattling aircon compressor pulley but sure there'll be more to come!!
  8. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #18
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Still wouldn't rule out seized or stiff vnt mechanism. High vacuum draw and no vane movement will put a stress on the turbo diaphragm. OP suggested no rod movement either which is a sure sign of sticky or seized vane mechanism. Trouble is VW will go "You need a new turbo Sir, that'll be a zillion pounds including VAT!"
    Mad Mitch
  9. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #19
    Nov 2010
    104 Post(s)
    Crossed my mind - one way to verify would be to remove actuator and move VNT by hand.
  10. Re: 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    #20
    1840 Post(s)
    Not seen it yet on these, the actuator diagram is split, simples....
  1. Replies: 6
    Last Post: 12-09-2019, 05:46 PM
  2. P0299 - 006 - Control Range Not Reached - Intermittent B6 Passat
    By silversimpson in forum VCDS - Help Requests
    Last Post: 25-07-2019, 08:37 AM
  3. Replies: 0
    Last Post: 27-05-2015, 04:21 PM
  4. P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
    By Benoticed in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-07-2013, 04:37 PM
  5. Please Help 000665 - Boost Pressure Regulation: Control Range Not Reached
    By SebRogers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2011, 11:01 AM
