Thread: Broken brake pad sensor
Results 1 to 8 of 8
  1. Broken brake pad sensor
    Apr 2016
    Durham
    I went to change the pads on my golf and the sensor was like this what can I do thanks
  2. Re: Broken brake pad sensor
    Jun 2016
    Glasgow
    Loop it out or renew car-side loom.
    Sent from my iPhone using Tapatalk Pro
  3. Re: Broken brake pad sensor
    Apr 2016
    Durham
    What does loop it out mean I'm a a novice thanks
  4. Re: Broken brake pad sensor
    Jun 2016
    Glasgow
    Electrically the two wires you see should be joined. This of course means your pad wear will no longer be monitored.
  5. Re: Broken brake pad sensor
    Apr 2016
    Durham
    So cut the end off and twist the two wires together?
  6. Re: Broken brake pad sensor
    Jun 2016
    Glasgow
    Pretty much.
    You'll want to clean, solder & heat shrink to insulate.
  7. Re: Broken brake pad sensor
    Apr 2016
    Durham
    Okay thanks for your help
  8. Re: Broken brake pad sensor
    Jun 2016
    Glasgow
    No problem.
  1. Broken MAF Sensor Housing
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-12-2011, 03:11 PM
  2. Rear Parking Sensor Sounds Broken
    By Mike2.0TQ in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-11-2011, 05:54 PM
  3. Light Sensor Broken?
    By microwork in forum Golf MK6 - 2009 - 2013
    Last Post: 09-03-2010, 03:33 PM
  4. parking brake is broken
    By knowledgeunltd in forum Golf MK2 - 1984 - 1992
    Last Post: 13-02-2009, 07:29 PM
  5. Exhaust Rattle - broken lambda sensor???
    By nice red GTi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-04-2007, 09:08 PM
