Thread: VCDS in Lanarkshire
Results 1 to 9 of 9
  1. VCDS in Lanarkshire
    Aug 2009
    Near Lanark
    17 Post(s)
    Just got myself a HEX V2 cable from Gendan and I'm based in Lanarkshire, ML11 Kirkmuirhill/Blackwood.
    Not sure how I go about being added to the map of users so hopefully a kind mod will see this and arrange it.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2009 Triumph Street Triple R | 105bhp | Matt Grey
    Novice VCDS owner - Lanarkshire Area. PM Me if you need help.
  2. Re: VCDS in Lanarkshire
    Oct 2017
    Airdrie
    I have an Ay and want some help unlocking some of the functions with VCDS, I don't have the system, can you help? Or should I just buy the cable and software?
  3. Re: VCDS in Lanarkshire
    Oct 2017
    Airdrie
    Sorry meant A7, 2015. Based in Airdrie, happy to meet up if you are able to help apply some of the VAGCOM updates.
    Thanks,
    Chris
  4. Re: VCDS in Lanarkshire
    Oct 2017
    Airdrie
    Hi Darius,
    I live in Airdrie and can come to you anytime.
    I'm looking to update the following via VCDS:
    Change the speed the High BeamAssist works from / to
    Close your boot remotely using yourkey fob (and retain the opening feature)
    Activate the hidden menu
    Activate the needle sweep
    Deactivate the seatbelt warningsystem
    Enable Import CDs to MMI's HD
    Enable Lap Timer
    Can you help, if so - cost?
    Thanks,
    Chris
  5. Re: VCDS in Lanarkshire
    Oct 2017
    Airdrie
    Perfect, Saturday morning OK, tell me when and where and a cost.
    Chris
  6. Re: VCDS in Lanarkshire
    Oct 2017
    Airdrie
    11am good for me, 20 is fine.
  7. Re: VCDS in Lanarkshire
    Aug 2009
    Near Lanark
    17 Post(s)
    Quote Originally Posted by J11CRM View Post
    You still good for tomorrow mate?
    Sent from my SM-G920F using Tapatalk
  8. Re: VCDS in Lanarkshire
    Oct 2017
    Airdrie
    Yes 11am. Thanks
  9. Re: VCDS in Lanarkshire
    Jun 2009
    England
    Hey there.
    Tried to pm but doesn't seem to let me?
    After a little help with a polo bluemotion, mostly to reset codes, do a regeneration and figure if I've got a bad maf and /upper lambda.
    Cheers!
  1. Vag com glasgow or lanarkshire HELP
    By kevin tdi in forum VCDS - Users Locations
    Last Post: 29-08-2013, 12:39 PM
  2. Replies: 12
    Last Post: 05-04-2013, 08:52 PM
  3. Replies: 0
    Last Post: 01-04-2013, 02:49 PM
  4. vcds help
    By solutio in forum VCDS - Users Locations
    Last Post: 27-04-2011, 02:15 PM
  5. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 04-01-2011, 11:21 PM
