Thread: VW Polo 9N driveshaft inner joint
  1. VW Polo 9N driveshaft inner joint
    Nov 2016
    Gainsborough GB
    Hi guys
    Driveshaft inner joint, inner race has 1 scoring as in the pictures.
    Would I get away for some years with repacking the joint with new grease and replace the boot or I should bite the bullet and pay for the new OEM inner joint as this scoring could cause an imminent joint failure leaving me stranded in the road?
    Cheers!
  2. Re: VW Polo 9N driveshaft inner joint
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I would replace - since you've already removed the unit it makes sense to replace it with new.
    Skoda Octavia II SE 1.9PD TDI
  3. Re: VW Polo 9N driveshaft inner joint
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    As said above, replace, as that joint is knackered.
  4. Re: VW Polo 9N driveshaft inner joint
    Nov 2016
    Gainsborough GB
    Well... It was not only the joint... The whole car was into pieces as I swapped the oil burning engine and gearbox for a newer one... New LuK clutch, etc.
    Cheers for opinions. Will do change the joint for new
  1. Please Help OS driveshaft inner CV joint worn excessively
    By DMitch16 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-02-2016, 10:25 PM
  2. Removing cv joint while driveshaft in situ
    By Chrisman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-04-2011, 04:46 PM
  3. Replies: 8
    Last Post: 28-02-2011, 01:18 AM
  4. Polo scrubbing driveshaft
    By dstv in forum Polo - Derby - Lupo - Fox
    Last Post: 20-07-2010, 10:43 PM
  5. CV Joint or complete driveshaft
    By polini130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-11-2008, 11:06 AM
